914-6 oil dipstick length and width |
mb911 |
Jan 18 2016, 04:27 PM
914 Guru Group: Members Posts: 6,882 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Guys as I finish up the 914-6 oil tanks I will be moving on to making the oil fill necks. Could anyone out there measure/dimension the dipsticks for me ?
fixer34 |
Jan 19 2016, 04:57 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Guys as I finish up the 914-6 oil tanks I will be moving on to making the oil fill necks. Could anyone out there measure/dimension the dipsticks for me ? Tried to take a picture, but it didn't come out well enough. Mine is 33cm from one end to the outer end of the loop/handle. The loop is 3.5cm and rests against the dipstick hole/pipe. The very end of the stick has a notch, I assume to indicate low oil level. 9cm up the stick is a dot which I've always used as the full marker. The stick itself is flat steel 1mm x 5mm, slightly curved. |
914Sixer |
Jan 19 2016, 07:19 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914Rubber has made them already.
mb911 |
Jan 20 2016, 02:08 PM
Lo-Fi Version | Time is now: 8th June 2024 - 08:02 PM |
