Front trunk t handle, locked with no key |
80cap |
Jan 25 2016, 06:44 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I purchased a new cable and guide from 914 rubber and went to install
it, the t handle is locked and the keys I have don't work. They don't work on any of the locks. Do I need to drill out he tumblers or any suggestions. Thanks Brian |
johnhora |
Jan 25 2016, 07:47 AM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Are you able to get into the front trunk?
If not you will have to remove the front bumper and there is a hole in the center of the front body metal right where the latch is located...you can open the lock there. Then you can remove the T handle...there are two small allen head bolts that hold it to the body....soak then good as they are usually hard to remove |
80cap |
Jan 25 2016, 07:53 AM
Yes the trunk lid is off. I see the two screws and will remove the t handle.
once its off any suggestions on how to rekey? |
TheCabinetmaker |
Jan 25 2016, 08:25 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You can send it to me and I'll fix it for ya.
Lo-Fi Version | Time is now: 7th June 2024 - 12:45 PM |
