bouncy tach, how much does palo alto charge to fix |
scotty914 |
Mar 18 2005, 07:05 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
title say it, i was wondering how much they charge to stop a tach from bouncing, with the tach working otherwise?
Trekkor |
Mar 18 2005, 07:27 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I called down there and they quoted $250. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Maybe I misunderstood them... KT |
seanery |
Mar 18 2005, 07:31 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Isn't bouncy tach a symptom of a poor ground? If so, check your grounds first. It's cheaper. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
SirAndy |
Mar 18 2005, 07:33 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) bouncy tach is usually *not* your tachs fault! i fixed mine (along with a few other gremlins) by getting a new relay board ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
scotty914 |
Mar 18 2005, 07:37 PM
well i will let the cat out of the bag
i found something internal that fixes some of the bouncy tach problems. i am just wondering what would be a fair price to charge for the service. i would feel guilty charging over 50 bucks, its not hard just takes some time. i would also calibrate the tach to 3000 rpms or so. |
Otmar |
Mar 18 2005, 09:41 PM
2000 Amps in a 914 Group: Members Posts: 174 Joined: 3-March 03 From: Corvallis, OR, USA Member No.: 387 |
Heck, I put a big fat cap on mine and now it's rock solid, except when the ground wire gets loose...
Matter a fact, here's my notes on it: Sun 04/25/04 06:26 PM Tachometer bounce getting to be too much, Added 2650 uF 10V across the coil winding. This helped a lot, no more bounce, reasonable response. Been great ever since. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
scotty914 |
Mar 18 2005, 09:48 PM
i found a mechanical thing inside that is affected by wear ( ie old age ) basicly if you smack you dash and it jumps i can fix it
Aaron Cox |
Mar 18 2005, 09:51 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
gigure out how to trigger a tach from a mallory cdi.... 12V squar wave at 20 percent duty cycle yada yada
scotty914 |
Mar 18 2005, 09:56 PM
not a problem, 3 parts needed a small capacitor, and transitor and another capacitor basicly the transistor can trigger to ground when it gets triggered by the cdi box, the capacitors are to level out the spikes |
Aaron Cox |
Mar 18 2005, 10:01 PM
make it happen for me! tell me what i need to do (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:49 AM |
