> A 914 Feature or 914 Problem, Parking Lights Turn On With Turn Signal
ChrisFix
post Mar 19 2005, 02:07 PM
I accidently hit the turn signal lever getting out of the car, and noticed that the left side parking lights (front and back) were on, corresponding to the turn signal lever being in the left position. This is with the key out of the ignition and the lights turned off. If I select the right side turn signal position, the parking lights on that side turn on. With the turn signal in the off position all the lights are off.
With the ignition on, everything works properly; turn signals, parking lights, headlights etc.
I just pulled the steering wheel and turn signal / wiper switches to replace the washer hoses and had to remove the gauges to get access so I have removed and reconnected the connector from the turn signal along with all the other bits and pieces to complete that job, so if this shouldn't be happening, I'm pretty sure it's related to this activity.
I never tried turning the turn signal on without power, so I don't know if that has always worked that way or if it is supposed to work that way.
Thanks for all the help I've been able to get from this forum!
Replies(1 - 6)
Kargeek
post Mar 19 2005, 02:13 PM
I believe this a parking feature held over on the US spec cars for the narrow roads in europe. You can park your car and depending on which side of the road you were on, you leave the signal lamp on to warn other cars. DH
sj914
I read somewhere that it's a safety feature used somewhere in Europe for when you park the car around town, people driving by can see your car so they can avoid crashing into it. I might be wrong though.
Reiche
post Mar 19 2005, 02:49 PM
Definitely a feature, as the other guys said. My Benz does the same thing but on the headlight switch. Newer Porsches have it there now too.
pete-stevers
post Mar 19 2005, 02:52 PM
saved from fire!
just found this out by acceident the other day I am sure glad that it is not a electrical poltergiest (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Howard
post Mar 19 2005, 02:54 PM
Incontin(g)ent Member
Yup, Euro requirement for parking at night on narrow streets. Either side lights up.
ChrisFix
post Mar 19 2005, 09:00 PM
Thanks for the confirmation. I was really hoping that this wasn't some sort of gremlin, as I checked and re-checked everything and couldn't find any reason for a problem. Funny how the timing works on discovering things like this - right after disassembling the switch.
Anyway, all is right in the 914 world...
- Lo-Fi Version Time is now: 4th July 2025 - 03:46 PM
