Wierd shift issue? |
falcor75 |
Feb 3 2016, 06:41 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I'm on the verge of getting my 94 out driving again after 3 years.
When i dryshift in the garage I can get all gears but changing from 2:nd to 3:rd I have to double clutch, but 2:nd to 4th goes flawlessly. I figured I'd ask before i experient further with the shifter settings. (Rennshift + Tangerine shift adjuster and Tangerine firewall bushing, all plastic bushings and cone screws are new) |
MJHanna |
Feb 3 2016, 07:13 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
Have you checked the free play on the clutch cable?
falcor75 |
Feb 3 2016, 12:08 PM
Doh.....I meant third to fourth is hard to get without doubleclutching, third to fifth works like a charm every time.
screenguy914 |
Feb 3 2016, 12:43 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Doh.....I meant third to fourth is hard to get without doubleclutching, third to fifth works like a charm every time. Upshifting from gear to gear (1>2>3>4>5) shouldn't be a problem since engine rpm decreases to match output shaft rotational speed. The typical issue is difficulty when downshifting from gear to gear. Since shifting to 4th seems to be the issue, how does it shift from 5th > 4th? S |
stugray |
Feb 3 2016, 01:57 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Dry shifting with the car not moving is always hit or miss.
I just learned to take the tools to make the adjustment with me when I go for the first drive. Plan on making the final tweaks on the side of the road. And once the engine is running, sit for a while and figure out your clutch engagement point. Having the clutch cable too loose is the #1 reason for shifting problems. |
r_towle |
Feb 3 2016, 04:06 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you have a side shifter....
a 13mm socket on a long extention for the shifter rod nut behind the shifter. A pair of vice grips to hold the shift rod while you adjust things, rear of seat via access hole. Two 11mm wrenches to loosen and tighten the clutch cable nuts under the car. a blanket to lay on. Go for a drive and keep adjusting till it works. Agree though, dry shifting is not a good way to know...the whole assembly needs to be moving and the oil should be hot, not below freezing, and yours is below freezing right now.. |
falcor75 |
Feb 3 2016, 11:22 PM
if you have a side shifter.... a 13mm socket on a long extention for the shifter rod nut behind the shifter. A pair of vice grips to hold the shift rod while you adjust things, rear of seat via access hole. Two 11mm wrenches to loosen and tighten the clutch cable nuts under the car. a blanket to lay on. Go for a drive and keep adjusting till it works. Agree though, dry shifting is not a good way to know...the whole assembly needs to be moving and the oil should be hot, not below freezing, and yours is below freezing right now.. I wont be able to really drive the car for a few months yet. I just wanted to get it as close as possible for the upcoming rolling road session, and my oil isnt that cold, got a nice constant 68 degrees in my garage. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:46 AM |
