Flywheel & Pressure Plate Question, Is there any hope for these? |
saigon71 |
Feb 3 2016, 02:31 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My clutch has never been the best...think I discovered why. (IMG:style_emoticons/default/dry.gif)
I gave my flywheel & pressure plate a close inspection today. Both show an odd discoloration. The best way I can describe it is "blotches." There is an odd wear pattern on my flywheel. The outer edge of contact point with the clutch (indicated with red sharpie line) is worn down .030 more than the rest. Can the mating surface of the flywheel be machined, or is this flywheel trash? Any hope for this pressure plate? Aside from the "blotchy" look, it is very smooth. I ran a straight edge across it. It is slightly convex, but I'm not sure how new ones are. Thanks. |
mepstein |
Feb 3 2016, 02:43 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Bob - I have a 1.7 short block that's supposed to be in very good condition. If you need any parts or want the whole enchalada, it's yours. $n/c
Attached image(s) |
r_towle |
Feb 3 2016, 04:01 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
My clutch has never been the best...think I discovered why. (IMG:style_emoticons/default/dry.gif) I gave my flywheel & pressure plate a close inspection today. Both show an odd discoloration. The best way I can describe it is "blotches." There is an odd wear pattern on my flywheel. The outer edge of contact point with the clutch (indicated with red sharpie line) is worn down .030 more than the rest. Can the mating surface of the flywheel be machined, or is this flywheel trash? Any hope for this pressure plate? Aside from the "blotchy" look, it is very smooth. I ran a straight edge across it. It is slightly convex, but I'm not sure how new ones are. Thanks. Find the flywheel specification diagram, its on about 50 threads here. measure yours...if it can be cut, do it. The pressure plate, it may have been the issue all along. its a spring that wears out.... Both look contaminated with oil, and burned. Rich |
saigon71 |
Feb 4 2016, 03:27 PM
ThePaintedMan |
Feb 4 2016, 06:01 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I agree with Rich, as usual. Those are hot spots, which is bad, particularly on a pressure plate. I had a Mustang which had a bad pressure plate which manifested itself as a bad clutch. It sucked to have put it all back together with a new friction disc when it was the PP all long. Solution is as above, measure the flywheel for machinable depth and replace pressure plate. Don't forget when you have the flywheel machined that you'll likely need to shim the clutch fork pivot ball when it all goes back together.
r_towle |
Feb 4 2016, 09:24 PM
I agree with Rich, as usual. Those are hot spots, which is bad, particularly on a pressure plate. I had a Mustang which had a bad pressure plate which manifested itself as a bad clutch. It sucked to have put it all back together with a new friction disc when it was the PP all long. Solution is as above, measure the flywheel for machinable depth and replace pressure plate. Don't forget when you have the flywheel machined that you'll likely need to shim the clutch fork pivot ball when it all goes back together. Yup. You machine the friction face You machine the step face that the pressure plate sits on, so the relationship between the two is the same as stock. You find out from the machine shop what they took off and you remove th clutch fork pivot ball and put the same amount of,shim under that ball,,,typically it's one or two washers |
Larmo63 |
Feb 4 2016, 10:06 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
A new PP, throw out bearing, and clutch on eBay is under $350. All new Sachs German stuff. Just get all new and re cut the flywheel if it can take it.
Why mess around with junk? |
Lo-Fi Version | Time is now: 10th June 2024 - 07:10 AM |
