Another stripping/painting question, Doing just the engine compartment |
dmilzoff |
Mar 20 2005, 09:46 AM
Member Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
I am having the engine removed and replaced next week. I want to strip repaint the engine compartment while it's out (at the mechanic's shop - outdoors). The car was repainted once and it has the original orange paint showing through the peeling blue car color.
I want to keep it simple and also not make a mess of the area. It is also only the engine compartment so it doesn't need to be a show paint finish. Is a rough sanding then using POR OK or will I be totally unhappy with the result? |
riverman |
Mar 20 2005, 10:54 AM
Learn As I Go Group: Members Posts: 449 Joined: 18-January 05 From: Kitchener, ON Member No.: 3,466 |
Why not strip the paint - either with a chemical stripper (easier, but fumy) or with a wire cup brush on the grinder (more work, but can be done) - so that you can see what shape the metal is like underneath. This will probably be the best time to ever do this. Then you can treat the metal with a rust converter and then cover with POR-15 or similar.
I look at it as short term pain for long term gain and you'll be happy with the result in the end. |
mharrison |
Mar 20 2005, 10:59 AM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
I would suggest that you have it sandblaster after covering the heater tubes and the area where the shift linkage and fuel lines enter the center tunnel. That will make quick work of it, take it to bare metal, and have it ready for primer.
I would think that there are enough nooks and crannies in the engine compartment to make chemicaly stripping it a real pain in the @$$. |
riverman |
Mar 20 2005, 11:07 AM
I agree, sandblasting is the easiest way once you get prepared, but in many areas (Ontario, Canada for one) sandblasting is only suppossed to be done by a licenced person for environmental reasons. Although, chemicals may be more harmful to the environment in the long run, it can be done legally and easily in one's own garage. Just be careful how you dispose of the waste. |
dmilzoff |
Mar 20 2005, 11:18 AM
The car will be at my mechanic's shop without the engine. It will not be easy (or inexpensive) to take it somewhere to sandblast it. And I don't want to make a mess at someone else's shop. I guess wire brushing would be the least offensive to the mechanic.
rhodyguy |
Mar 20 2005, 11:29 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
protect the wiring, degrease it, wire wheel and 3-M pads to rough it up and clean the loose stuff, another degrease, rust treatment(por-15, osphoric acid, Mar-hyde), self etching primer, and a couple of finish coats. if you have a color code for the paint an auto body supply store can load rattle cans with paint for you. now is a good time to lose the sound pad. not knowing how far your mechanic is from your house, or how long the engine will be out, a tow home and back might be a good investment.
k |
Lo-Fi Version | Time is now: 9th June 2024 - 10:36 AM |
