| IAA1963 |
Feb 8 2016, 02:11 PM
Newbie ![]() Group: Members Posts: 46 Joined: 8-October 11 Member No.: 13,652 Region Association: None |
Hi,
I want to give some parts of my original /6 the original finish again. They are sandblasted, but I am not sure which parts have had zink or paint finish originally. I think the break shield are yellow zink plated for a /6 and the tank filler unit should be black painted as well as the holder for the muffler. But what about the remaining items. My /6 is being restored as per original specs and I want to have the details right, too. Thank you. Mark ![]() |
| Tom_T |
Feb 8 2016, 02:22 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Hi, I want to give some parts of my original /6 the original finish again. They are sandblasted, but I am not sure which parts have had zink or paint finish originally. I think the break shield are yellow zink plated for a /6 and the tank filler unit should be black painted as well as the holder for the muffler. But what about the remaining items. My /6 is being restored as per original specs and I want to have the details right, too. Thank you. Mark ![]() IIRC the muffler hanger (top), rear brake shields (2nd row L) & gas tank filler/overflow tank (bott/rt.) were all the factory satin black paint finish - like what looks to be an NOS front brake shield at the 2nd row top right - on all 914s 4/6 - so if that's an original part with original finish, you have the match for your painter or PC shop to use with it - keep that as is if it's the genuine Porsche part on the sticker. Recheck below guys one the rear shields. The rear shock spacers ("L" shaped in 3rd row 2 over from fuel overflow) were silver zinc. IIRC the the shock top caps are black too - but check with socalandy & toolguy on here by PM for that & the other parts. PM them directly since they may not see this otherwise. PS - 3 suggestions - 1. Take pix of everything - EVERYTHING - before they come off, as you disassemble, & before you strip them. Then you have a record of where the parts go, how they assemble & ancilliary parts, & what the finish was before (if not originally). A big aid in getting it refinished correctly & put back together correctly. Digital SD cards are cheap insurance! 2. Use walnuts, small beads or other less-aggressive-than-sand media to strip your parts - or dip strip them, to avoid metal distortion & excessive pitting. 3. Also, if you come across rust in your resto, EvapoRust is an excellent & non-toxic rust remover available all over - so a pre-soak in that may eliminate the need to blast many parts at all, only leaving you to clean off the Evapo & sand for smoothness - since it will leave pits where the rust was if deep rust (or at least a ex-rusty surface roughness afterwards). PSS - Thanx for the correction on the camber plates sbsix. If you have correct pix of them & other parts, it may help the OP get his in order! (IMG:style_emoticons/default/shades.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| sbsix |
Feb 8 2016, 02:28 PM
only the lead dog enjoys a change in scenery... ![]() ![]() Group: Members Posts: 463 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California
the shock top camber plates are yellow zinc plated
| pete000 |
Feb 8 2016, 03:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Brake dust shields are yellow zink. Later cars were black.
| siverson |
Feb 8 2016, 03:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,464 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California
> Brake dust shields are yellow zink Yes, that's right those are yellow, but I thought it was yellow cadmium, not yellow zinc. Not that is makes that big of difference, but yellow cad does look a little different. -Steve |
| sbsix |
Feb 8 2016, 04:34 PM
You are right, originals were cadmium plated, but you can't cad plate anymore so everyone has to use yellow zinc.
| IAA1963 |
Feb 8 2016, 05:02 PM
Thank you all for the feedback ... as there are different anserws on the brake shields ... I am still not sure if they should be black or yellow?
Tom, thank your for your suggestions. The car as well as most of of the parts have been soda blasted and only the rusted areas have been sand blasted. I have also plenty of pictures of everthing, but brake shield etc were in terrible condition so I did not know... I even made pictures of the tar on the floors, which I have reproduced accordinlgy and glued into before painting ... Plenty of NOS parts used: |
| siverson |
Feb 8 2016, 07:32 PM
Great photos.
Brake shields on sixes were definitely yellow. One of the neat differences IMO. http://www.914world.com/bbs2/index.php?s=&...t&p=2083620 -Steve |
| Eric_Shea |
Feb 9 2016, 10:23 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Zinc is a better rust protectant.
Bearing Caps = Yellow Zinc Front Dust Shields = Yellow Rear Dust Shields = Black Shock Caps = Black. Only yellow on later SC's Alignment Plates = Yellow Everything else black as described. Your call on the alignment shims. I'd have a nice heavy coating of clear zinc on them. |
Lo-Fi Version | Time is now: 8th August 2026 - 10:20 PM |
