Installing dash face vinyl, 914 rubber late model |
80cap |
Feb 8 2016, 04:35 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Do you need to drop the steering wheel to fit the metal backing plate onto to the dash?
I want to instal the vinyl to the backing plate then using double sided 3m tape attach the plate to the main dash. Also the kit doesn't include a plate for the glove box door. I assume it doesn't need it. Thanks Brian |
80cap |
Feb 9 2016, 05:53 AM
Anyone use this system?
mepstein |
Feb 9 2016, 06:04 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Steering wheel is a 25mm socket (I think) you loosen it most of the way, pull on the wheel to break it free and then take the nut off the rest of the way. Just gives you more room to work. No metal plate on the glove box door.
Darren C |
Feb 9 2016, 06:51 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
If you are asking about the basket weave panel......YES the Steering column needs to be removed to do the job properly.
The metal backing panel is linked together across the top of the steering column so you cant get it off without removing the column or dare I say cutting it in two (which is NOT a long term good idea for the sake of another 15 minutes to take out the column two bolts and one universal joint bolt, especially as you'll have spent a good time taking out all the switches, knee roll, heater controls, cigarette lighter and radio!) You also ideally need to take the glovebox door off to do a good job recovering it, especially the return fold over. |
Mikey914 |
Feb 9 2016, 09:56 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes, it's a pain, but you do need to remove it.
malcolm2 |
Feb 9 2016, 10:14 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I need to do this too. I assume you just remove everything attached to the panel, (fresh air controls, knobs, cig lighter, knee pad, etc...glue the vinyl on.... wait a while, then re-install all the knobs, etc.... That does sound like a pain, wish I had done it when I had it all apart a few years back.
lsintampa |
Feb 22 2016, 09:43 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I just did mine and yes you need to "drop" the steering wheel. Removing all the light switches and the heater control is obviously mandatory.
BTW - when you have to deal with that heater control assembly, the best thing is to remove the two cables that connect to the left front air valve controller - just make sure you label them. Disconnect from the front hood - then pull them into the cabin. Then remove only the one cable inside (top level of the heater control assembly). That seemed to be the easiest way. Label all wires - I have one ground wire now that I'm not sure where it goes. If I run it directly to ground - my fresh air blower light is constant on - regardless of position of the blower motor switch. I think that it grounds to the assembly somewhere. Anyway back to the wheel situation. Best to lower the whole thing. Unbolt the 4 bolts that hold it up then you have to wiggle fit the face on. Worked for me that way. Good luck! Len Do you need to drop the steering wheel to fit the metal backing plate onto to the dash? I want to instal the vinyl to the backing plate then using double sided 3m tape attach the plate to the main dash. Also the kit doesn't include a plate for the glove box door. I assume it doesn't need it. Thanks Brian |
914Sixer |
Feb 22 2016, 05:39 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
75-76 DOES NOT have a metal plate like the early cars. The material is heat sealed on to some sort of stiff plastic.
Lo-Fi Version | Time is now: 8th June 2024 - 11:41 AM |
