| jmitro |
Feb 12 2016, 11:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
two questions about using weld thru primer, (assuming that proper usage is spraying primer on the backside of two adjoining pieces so that primer covers the bare metal that cannot be accessed once welding is completed);
1. Do you change the weld settings on the welder? It welds terribly with poor penetration. Or do you grind off the primer from the anticipated weld spot? If so, then it's defeating the purpose of weld-thru primer, is it not? it leaves bare metal. 2. After welding is complete, do you grind off the exposed weld-thru primer and replace it with POR-15 or primer of choice? |
| bretth |
Feb 12 2016, 12:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
My experience with weld through primer has been that it makes for awful welds. So my use of it was to mask off areas that are going to be welded and then spray it everywhere else.
Brett |
| 76-914 |
Feb 12 2016, 01:21 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,866 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Try putting it on a little thinner. It helps.
| SirAndy |
Feb 12 2016, 01:54 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Try putting it on a little thinner. It helps. And don't inhale the fumes while welding ... (IMG:style_emoticons/default/icon8.gif) |
| Elliot Cannon |
Feb 12 2016, 02:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Try putting it on a little thinner. It helps. And don't inhale the fumes while welding ... (IMG:style_emoticons/default/icon8.gif) I have found that inhaling the fumes improves my welding. Who knew? (IMG:style_emoticons/default/av-943.gif) |
| doug_b_928 |
Feb 12 2016, 02:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
From what I have seen, people spray it on what will be the 'heat affected zone', and then use a flatened drill bit to remove it from the exact spot where the weld will go, this way keeping primer on the metal that will not be covered by the weld.
| r_towle |
Feb 12 2016, 03:16 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Try putting it on a little thinner. It helps. And don't inhale the fumes while welding ... (IMG:style_emoticons/default/icon8.gif) I have found that inhaling the fumes improves my welding. Who knew? (IMG:style_emoticons/default/av-943.gif) I found that inhaling fumes makes my outlook on everything different. |
| Bartlett 914 |
Feb 12 2016, 03:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
The fumes are from the zinc in the primer. Burning the zinc gives off small amounts of Chlorine gas FWIW
| r_towle |
Feb 12 2016, 03:28 PM
I spray on the primer, then grind off the spot welds I an going to weld.
I feel better that there is some primer on the back side. If I am doing a seam weld, Its all bare anyways so I can work the joint from both sides and hammer dolly it flat, grind it, then prime it when done. The spot welded seams, like all over our cars, is where I use it. Never use it anyplace else. Cannot weld through it.... rich |
| Jeff Hail |
Feb 12 2016, 08:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
The best method is to coat both pieces that face each other that you are welding. Scratch, grind , sand a small margin to bare metal where the nugget is going to land. I also clean the area on the back side of the punched or drilled hole. Good clean metal to metal contact.
1) First think clean welds. 2) If you are seeing green flashes of arc light you were born in the 60's or 70's, did not have a clean weld zone and are burning zinc up. It looks bitch'n but its really a stellar way to contaminate welds. 3) The cleaned nugget zone should be a little larger than the pilot hole. I normally clean about a dime size area to get good cut into the lower panel. Zinc and or copper weld sprays melt at very low temperature. The concept is to have a clean weld and let the weld spray just melt around the weld area. Welding through a dissimilar metal to join two similar materials well would be like strippers sitting on your lap because you think they actually like you. The word "Strippering" originated from that false belief from sugar baby hell that $2 buys a nut and also applies to many things in life including welding. Don't do it, its a trap! Everything cools down and the weld spray makes a metallic seal around the weld zone theoretically encapsulating it. The second life of weld sprays to is to provide a sacrificial coating between the joined panels to retard corrosion . Zinc or copper will oxidize much slower than steel buying time as a barrier by chemical reaction. A few good tips: You don't need two or three heavy coats. One even coat is fine. Zinc is pretty much heavy metal so use adequate ventilation or push the fumes away with a slow speed fan. Green arcing is not so good, the weld is stopping and starting by resistance while contaminating itself. White crud on your welds that looks porous is exactly that. |
| larryM |
Feb 12 2016, 10:30 PM
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California
consider this expert advice Ron Covell advice "Q. I'm doing my own paint- and bodywork, Should I use weld-through primer for patch panels, or is it better to use a rust inhibiter after welding by dipping, or sealing, one side of the joint and flooding the other? A. The answer to your question depends to some degree on the type of welding you do. TIG and gas welding are pretty sensitive to surface contamination, so these process would not be a good fit with weld-through primers, in my opinion. If you are MIG welding, which is much less sensitive to surface contamination, you can make a case for using a good-quality weld-through primer. I've always preferred TIG welding, so the approach I'd take is carefully sealing the joint after welding." |
| 914forme |
Feb 13 2016, 11:20 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
The best method is to coat both pieces that face each other that you are welding. Scratch, grind , sand a small margin to bare metal where the nugget is going to land. I also clean the area on the back side of the punched or drilled hole. Good clean metal to metal contact. (IMG:style_emoticons/default/agree.gif) You can take anything Jeff Hail says about this process to the bank. BTW if you have an afternoon to kill read his build thread, I learned more in that thread, and another one on Garage Journal, than I have in a life time of doing stuff wrong. |
| jmitro |
Feb 13 2016, 11:58 AM
no doubt! Thank you so much for all the helpful replies. I guess I assumed "weld-thru primer" meant I could weld right on top of it, but I guess not. Good information to know! I'll make sure I have good clean metal from now on. Thanks again!! (IMG:style_emoticons/default/beerchug.gif) |
| JoeDees |
Feb 13 2016, 07:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I have some brush on stuff that is the king of splatter. Stick with a good spray like 3M or Copperweld.
| 914forme |
Feb 13 2016, 07:58 PM
I use Wurth
![]() Zinc Rich Weld Through Primer Description 13.53 fl. oz. Aerosol Features - 98 - 99% pure zinc content - Long term cathodic protection for all metallic surfaces - Adheres reliably to all metals - Heat resistant up to 914ºF - DO?NOT apply filler after application - Good electrical conductivity - Special epoxy resin for better adhesion 914 degree heat resistance is why I use it has to be an a sign from the 914 Gods (IMG:style_emoticons/default/smiley_notworthy.gif) |
Lo-Fi Version | Time is now: 4th March 2026 - 01:18 AM |
