motomoss |
Newbie ![]() Group: Members Posts: 4 Joined: 1-July 12 From: New Buffalo MI Member No.: 14,620 Region Association: None ![]() |
Hello, I currently have 1974 2.0 and am thinking on purchasing a big bore kit for it. I have a set of Weber dual 40's and distributor set up for carbs that I will be using on the car but do not know the correct main jet size for the carbs (IMG:style_emoticons/default/confused24.gif) . Any help would be much appreciated.
Starlack |
Member ![]() ![]() Group: Members Posts: 67 Joined: 8-January 12 From: Germany Member No.: 13,978 Region Association: None ![]() |
Hello, I currently have 1974 2.0 and am thinking on purchasing a big bore kit for it. I have a set of Weber dual 40's and distributor set up for carbs that I will be using on the car but do not know the correct main jet size for the carbs (IMG:style_emoticons/default/confused24.gif) . Any help would be much appreciated. Hello I have documents from a German engine builder. Porsche 914 Venturies 30mm Mixing tube F11 Main Jet 125 Idling jet 55 Regulating nozzle 180 evtl.200 hope to have helped |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Hello, I currently have 1974 2.0 and am thinking on purchasing a big bore kit for it. I have a set of Weber dual 40's and distributor set up for carbs that I will be using on the car but do not know the correct main jet size for the carbs (IMG:style_emoticons/default/confused24.gif) . Any help would be much appreciated. Hello I have documents from a German engine builder. Porsche 914 Venturies 30mm Mixing tube F11 Main Jet 125 Idling jet 55 Regulating nozzle 180 evtl.200 hope to have helped This might be a good place to start but depending on engine size you might have to do a little experimenting with jet combinations |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
It's an air correction jet instead of a regulating nozzle here in the States. Buy the weber tech manual by Bob Tomlinson. Read it until you understand how the carb works. I had to read it several times before i wrapped my head around all of it.
You'll need to buy a carb cam too. Otherwise you won't be pleased with the performance. |
Lo-Fi Version | Time is now: 31st July 2025 - 10:52 AM |
