adidas |
Member ![]() ![]() Group: Members Posts: 489 Joined: 6-February 03 From: Charlotte NC Member No.: 250 ![]() |
Anyone have a new or good used Pertronix Ignitor electronic ignition module? Thanks Bill
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
RenoRoger |
Member ![]() ![]() Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California ![]() ![]() |
And don't forget to carry a set of points. I have had three of these "wonderful" electronic units fail on me over the years. |
BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
And don't forget to carry a set of points. I have had three of these "wonderful" electronic units fail on me over the years. You have something else going on. The only set that I trashed was from leaving the switch on. I had a set on a Ghia for over 10 yrs and 6 years on my 914. That being said I carry a spare set. If they crap out it is easier to replace them with the same. Especially on the road side w/o a dwell meter. |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
This is one of the best mods you can do to make you 914 run better. These units will be damaged if the polarity is reversed, even for a moment.
I installed my first unit in 1989 when the company was called Per-Lux, the dizzy cap had to be shaved down on the inside to accomodate the size of the original unit. Things are a little better today as the have a specific unit to fit the 914 dizzy without modification. Yes I keep a set of points and condenser in my tool kit but I've never had to swap them in. (I used to keep another dizzy with points in the trunk just in case, belt and braces as they say!) Good luck, Mike |
Lo-Fi Version | Time is now: 15th June 2024 - 05:40 AM |
