> 1971 Ignition switch what to use, 1971 914-4 Frankenstein
mikesjunk
post Feb 17 2016, 04:46 PM
So my ignition switch/tumbler is out being un-Frankensteined by Dan Roman and getting some new keys to boot. In the process I'm going to need a new switch, electrical part. My research shows no real replacement for the 1971s and the feedback from Dan was there are two choices a 4 wire VW or a 6 wire VW. My original switch had 4 wires, only 3 were hooked up.
So here's what I have. I believe the column is original as best as I can tell. It has a 14 pin connector. So as wired prior to removal only 3 wires were being used. Which would be 12V in, 12V keyed and start. On the harness side I have 5 wires. Plus I have an additional grey wire coming from the column not part of the 14 pin harness(seen at top of photo).
I'm guessing the 4 wire VW gets me what I need(but not fully original) so any suggestions.
Below the blue/brown and the yellow/black weren't hooked up to anything. (bottom two) If anyone knows right off what these are it would be appreciated as the wiring diagram, even blown up larger, it still a challenge.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1455749176.1.jpg)
Replies(1 - 1)
pdlightning
post Feb 17 2016, 10:59 PM
Pdlightning
QUOTE(mikesjunk @ Feb 17 2016, 02:46 PM) *
The replacement units have been type 3 only for the 914. It is a one year item. Some people have had switches that are 5 wire stock and the aftermarket units are 4 wires. On my 71, people say to replace the column and the switch to a later model. I am in the same boat and thinking the later model steering column might be the way to go!
- Lo-Fi Version Time is now: 14th March 2026 - 08:06 PM
