So here's what I have. I believe the column is original as best as I can tell. It has a 14 pin connector. So as wired prior to removal only 3 wires were being used. Which would be 12V in, 12V keyed and start. On the harness side I have 5 wires. Plus I have an additional grey wire coming from the column not part of the 14 pin harness(seen at top of photo).
I'm guessing the 4 wire VW gets me what I need(but not fully original) so any suggestions.
Below the blue/brown and the yellow/black weren't hooked up to anything. (bottom two) If anyone knows right off what these are it would be appreciated as the wiring diagram, even blown up larger, it still a challenge.
