Speaking of Holes...., Not what you think.... |
dakotaewing |
Mar 21 2005, 10:36 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
I need (read want) to cut or drill some holes in a couple of spots in my car...
Some of these will be on the top of the center tunnell... I want these to be perfectly round, not a hack job with a sawzall... I am thinking at least 1.5" in diameter... What do I use to do these? I know it sounds like a stupid question, but hole saws or bits, from what I have seen, are for wood - not metal... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Thanks |
scotty914 |
Mar 21 2005, 10:42 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
normal hole saws will do metal but you will have some clean up to do, then there is the unibit or stepped bits are the way to go, pricey but the way to go.
jim912928 |
Mar 21 2005, 10:43 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
go to lowes...they sell a slew of hole saws of various diameters with the starter drill bits in the center for metal. That is what I used to drill the perfectly round holes for my front sway bar.
dakotaewing |
Mar 21 2005, 10:49 PM
Cool! Thanks Jim - |
scruz914 |
Mar 21 2005, 10:53 PM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
When cutting metal run the drill slower than you would when cutting wood. A hole saw will eventually cut through. Give it an occasional rest to cool down. You might want to drill a pilot hole with a slightly smaller bit than the one in the hole saw. A pilot hole will insure that you end up with your final hole where you want it. Be careful at the end of the cut. With all of the pressure you will probably be bearing down with the bit and saw can break through into the tunnel and you could damage the wires or fuel lines underneath.
-Jeff |
dakotaewing |
Mar 21 2005, 11:01 PM
Jeff, Thanks for the heads up, but ALL that stuff is YANKED.... I want to drill these holes before I do a major rust clean up/restore of the center tunnel.. Everything is out, the tunnel needs to be treated for rust, and everything replaced... -Thom |
TheCabinetmaker |
Mar 22 2005, 07:21 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Thom, Lowes. Bimetal hole saw. piece of cake
Flat VW |
Mar 22 2005, 08:42 AM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
One will also get a better result when using hole saws in steel if one applies some WD-40 (or equal) to lubricate (and cool) the bit and the steel to be cut.
If one uses the lube they may get the hole saw to cut many more holes than just one. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) I think one will find with the lube added , one will not need to 'rest" the hole saw although one may need to rest one's arms. John (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Boy, that is a lot of 1s (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
JWest |
Mar 22 2005, 08:57 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I agree - bimetal works well. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:53 AM |
