Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,198 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
Starting to reassemble things after rebuilding trailing arms, dropping engine, etc.
I plan to replace the rear brake lines and hoses while I am at it. In looking at rear hoses at PMB I see the following comment: "This is one of the toughest jobs on a 914 but, if you need them... you need them." Just curious, what makes this difficult? Does the engine or trailing arm block something (hard to tell with them both out). I just want to make sure I put everything back together in a logical sequence. |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
With the engine and exhaust on, space is very tight which is what makes it so difficult. If you have the engine out its a breeze.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,324 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
The fact that it's tough means that it might not have been done for a long time. Spray the fittings ahead of time to start loosening up the corrosion. Capt Crusty taught me a trick that often comes in handy. First tighten a corroded bolt, screw or fitting. Even a tiny bit. It often breaks it free and then loosens up easily.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
In my case, it was because Erc shipped me the wrong hoses. (IMG:style_emoticons/default/mad.gif)
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
With the engine and exhaust on, space is very tight which is what makes it so difficult. If you have the engine out its a breeze. (IMG:style_emoticons/default/agree.gif) I managed to do this with the engine in, but it IS very tight and was painfully slow in terms of making progress loosening and tightening. Make sure you have a proper 11mm brake (flare nut) wrench to do the job. And/or an 11mm flared crowfoot may make it easier. |
mepstein |
When I did mine I bent up the hard lines that run to the bulkhead and had to remove it and replace, turning the nut on the pressure regulator 1/64 turn at a time. Engine in the car. Fun times.
BeatNavy |
1/64 turn at a time. That's about right! Struggle to get wrenches on. Turn 1/64th of a turn. Repeat. (IMG:style_emoticons/default/headbang.gif) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Make sure you use a Flare Nut wrench when removing brake lines.
Lo-Fi Version | Time is now: 16th June 2024 - 02:17 PM |
