Starting to reassemble things after rebuilding trailing arms, dropping engine, etc.
I plan to replace the rear brake lines and hoses while I am at it. In looking at rear hoses at PMB I see the following comment:
"This is one of the toughest jobs on a 914 but, if you need them... you need them."
Just curious, what makes this difficult? Does the engine or trailing arm block something (hard to tell with them both out). I just want to make sure I put everything back together in a logical sequence.
