Rear Brake Hoses |
Rear Brake Hoses |
Amphicar770 |
Feb 24 2016, 09:27 AM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Starting to reassemble things after rebuilding trailing arms, dropping engine, etc.
I plan to replace the rear brake lines and hoses while I am at it. In looking at rear hoses at PMB I see the following comment: "This is one of the toughest jobs on a 914 but, if you need them... you need them." Just curious, what makes this difficult? Does the engine or trailing arm block something (hard to tell with them both out). I just want to make sure I put everything back together in a logical sequence. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:10 AM |
