Fixed my odometer |
Fixed my odometer |
PanelBilly |
Feb 25 2016, 09:29 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
While the speedometer worked fine, the odometer wasn't working at all. Pelican has a technical write up on how repair them. I jumped right in and tore it open. Taking the barrel of numbers apart wasn't all that hard, but getting them lined up again took me a fair number of attempts. I figured it was best to just line up all the zeros, but the first roller slipped. Guess I'm starting the car over with 2 miles on it. Its not far from the truth
timothy_nd28 |
Feb 25 2016, 10:55 PM
Looks like you did a good job getting things realigned which can be a super PITA sometimes. I typically remove the face dial and run masking tape across all the wheels. This makes life easier keeping the wheels together as you pull out the supporting shaft. In addition to what the Pelican write up says, I also put a dab of locktite inside the free wheeling gear.
Mark Henry |
Feb 26 2016, 12:09 PM
Posting the link is OK here for something like this.
This is the "how to" right? http://www.pelicanparts.com/techarticles/1...eter_Repair.htm I wonder if this is basicly the same repair for an old VW speedo and for my Fiat tractor hour meter. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 06:56 AM |
