WTB; front suspension conversion parts |
fduval |
Mar 1 2016, 07:16 AM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
Hi , looking to buy parts to convert from 4 lugs wheels to 5 lugs wheels, therefore I need all the components for the front , ie A Arms with torsion bars, front struts, brake components and hub. My car is a 1973 2 liter.
Let me know what you have , must be in very good condition. thanks Francois |
mepstein |
Mar 1 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A arms & torsion bars can remain the same.
Edit above |
fduval |
Mar 1 2016, 08:38 AM
A arms can remain the same. Great thanks for the tip...... (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Mar 1 2016, 08:53 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
A arms can remain the same. Great thanks for the tip...... (IMG:style_emoticons/default/biggrin.gif) If you go with 911 A arms you will have larger 19mm torsion bars. Keep in mind suspension is a system. Any component you add affects the others. If you go with 911 A arms you should go with stiffer than stock rear springs for best handling. Bruce |
fduval |
Mar 1 2016, 09:38 AM
A arms can remain the same. Great thanks for the tip...... (IMG:style_emoticons/default/biggrin.gif) If you go with 911 A arms you will have larger 19mm torsion bars. Keep in mind suspension is a system. Any component you add affects the others. If you go with 911 A arms you should go with stiffer than stock rear springs for best handling. Bruce Thks Bruce . Actually have rear Bilstein sport shocks with 140 lbs springs. Francois |
Lo-Fi Version | Time is now: 7th June 2024 - 11:28 AM |
