fduval
Mar 1 2016, 07:16 AM
Hi , looking to buy parts to convert from 4 lugs wheels to 5 lugs wheels, therefore I need all the components for the front , ie A Arms with torsion bars, front struts, brake components and hub. My car is a 1973 2 liter.
Let me know what you have , must be in very good condition. thanks
Francois
Mar 1 2016, 07:46 AM
A arms & torsion bars can remain the same.
Edit above
fduval
Mar 1 2016, 08:38 AM
QUOTE(mepstein @ Mar 1 2016, 05:46 AM)
A arms can remain the same.
Great thanks for the tip......
bdstone914
Mar 1 2016, 08:53 AM
QUOTE(fduval @ Mar 1 2016, 08:38 AM)
If you go with 911 A arms you will have larger 19mm torsion bars. Keep in mind suspension is a system. Any component you add affects the others. If you go with 911 A arms you should go with stiffer than stock rear springs for best handling.
Bruce
fduval
Mar 1 2016, 09:38 AM
QUOTE(bdstone914 @ Mar 1 2016, 06:53 AM)
Bruce
Thks Bruce . Actually have rear Bilstein sport shocks with 140 lbs springs.
Francois
