WTB; front suspension conversion parts |
fduval |
Mar 1 2016, 07:16 AM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
Hi , looking to buy parts to convert from 4 lugs wheels to 5 lugs wheels, therefore I need all the components for the front , ie A Arms with torsion bars, front struts, brake components and hub. My car is a 1973 2 liter.
Let me know what you have , must be in very good condition. thanks Francois |
Mar 1 2016, 07:46 AM
A arms & torsion bars can remain the same.
Edit above |
fduval |
Mar 1 2016, 08:38 AM
A arms can remain the same. Great thanks for the tip...... (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Mar 1 2016, 08:53 AM
A arms can remain the same. Great thanks for the tip...... (IMG:style_emoticons/default/biggrin.gif) If you go with 911 A arms you will have larger 19mm torsion bars. Keep in mind suspension is a system. Any component you add affects the others. If you go with 911 A arms you should go with stiffer than stock rear springs for best handling. Bruce |
fduval |
Mar 1 2016, 09:38 AM
A arms can remain the same. Great thanks for the tip...... (IMG:style_emoticons/default/biggrin.gif) If you go with 911 A arms you will have larger 19mm torsion bars. Keep in mind suspension is a system. Any component you add affects the others. If you go with 911 A arms you should go with stiffer than stock rear springs for best handling. Bruce Thks Bruce . Actually have rear Bilstein sport shocks with 140 lbs springs. Francois |
Lo-Fi Version | Time is now: 17th May 2024 - 03:25 PM |
