914-6 fuel pump fuse? |
xsurfer |
Mar 1 2016, 12:47 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Where is the fuse to a factory six fuel pump. I've looked at the books I have but
can't find it. Is it the 30 amp fuse on the relay board? Thanks Gene |
toolguy |
Mar 1 2016, 12:48 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Unfused, direct feed from the ignition switch
same as the cd box |
xsurfer |
Mar 1 2016, 02:12 PM
Peashooter |
Mar 1 2016, 02:56 PM
Member Group: Members Posts: 164 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
The feed to the fuel pump is direct from the ignition key, no relay or fuse. You would have to disconnect the wires at the pump or interrupt the wire coming off the switch.
Lo-Fi Version | Time is now: 10th June 2024 - 02:17 AM |
