Foggy Gauges, What can I do ? |
914Rookie |
Mar 23 2005, 11:40 AM
Newbie Group: Members Posts: 38 Joined: 7-May 04 From: La Verne, CA Member No.: 2,033 |
My gauges get progressivley foggy when I drive (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) . They are never clear but seem to fog worse when the heater is on. Is there a way to pull the lense from the gauges without damaging them?. Anyone else have his problem ?. Thanks
Greg |
Marlow |
Mar 23 2005, 12:30 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
Not an easy job but it is possible. Removing the trim rings is time consuming and can be done with very little damage if careful. Basically you use a small knife or screwdriver to bend the lip of the trim rings outward until they can be popped off the gauge.
Sorry I don't have any pictures. Someone may have pictures of this procedure. |
Aaron Cox |
Mar 23 2005, 12:37 PM
uncrimp the housing.....its a PITA to do without damage
CptTripps |
Mar 23 2005, 12:43 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Might be easier to just replace them. You can get a decent set of used guages for under $100...
Marlow |
Mar 23 2005, 12:45 PM
Part of this Pelican article might help . . . it has some photos of removing the trim rings.
http://www.pelicanparts.com/techarticles/M...auge_repair.htm |
machina |
Mar 23 2005, 12:54 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
WAIT
On my 911, used to have that problem. Drill a small hole, maybe 3/8" in the back of the gauge case. That will equalize the humidity inside and outside of the gauge. No more fog. |
914Rookie |
Mar 23 2005, 01:01 PM
Some good suggestions (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) ... I think I'll try pulling them and seeing if I can't get them open around the trim ring without screwing them up. Then after cleaning the lense I like the idea of equalizing the humidity ( but 3/8" seems like a big hole for the back of the gauge? ). Thanks for the input.
Greg |
mharrison |
Mar 23 2005, 01:02 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
You have a HEATER???? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
machina |
Mar 23 2005, 01:23 PM
forget it, I butched mine. It's a real bitch. |
Type 4 |
Mar 23 2005, 01:27 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Take them out and put them in the oven. I warm the oven up at the lowest setting 200 degress.
Turn it off wait about 15 minutes then set them in face down on the rack and leave over night. |
double-a |
Mar 23 2005, 01:39 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
remove any bulbs from the back first. the gauges aren't completely airtight, and a good bit of heat will drive the moisture out. ~a |
SirAndy |
Mar 23 2005, 02:35 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
get the standing water out of your car! probably behind the seats or maybe your fresh air box drain is clogged ... once the inside of the car is dried out, the foggy gauges will clear up! (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
914Rookie |
Mar 23 2005, 04:19 PM
I'll try the oven thing ( I hear the gauges taste like chicken !) to dry them out but my car always has the top off ( So Cal ) and is garaged 100% of the time so I don't think there is any moisture sitting in the interior. I'll refrain from pulling the lenses for now.It may be an open heater duct getting air behind the dash?. Thanks again for all the help. Any more suggestions?...these have been really good.
markb |
Mar 23 2005, 04:59 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Being a 75, would those gauges have the plastic lenses? Would the oven damage the plastic?
double-a |
Mar 23 2005, 05:04 PM
good point, but it's hard to tell what years used what materials for the gauge faces. our 75 has all plastic faces, the 74 has one plastic face. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
~a |
914Rookie |
Mar 23 2005, 05:05 PM
Yup... I think they are plastic. I'll give them a good look'n at tonight when I get home and see what can be done. Thanks.
Greg |
ChrisFix |
Mar 23 2005, 05:32 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
My '74 does the exact same thing...the gauges fog a little as they warm up from the heat of the bulb. I have found that if I just leave the lights on long enough, that seems to dry them out. Don't know why it's there either; my car is always garaged and is perfectly dry, so it must just be humidity from sitting. The idea of putting a small breathing hole in the back sounds like a good one. I'm going to look into that this weekend. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:54 AM |
