Rear window removal for cage install?? |
Mueller |
Jun 15 2003, 10:38 AM
I have all of the interior out (including dash and dash pad)
I was told that removal of the front winshield will make the install of the cage go smoother , but what about the rear window??? The windshield needs to be pulled anyways since it is cracked pretty bad. |
jonwatts |
Jun 15 2003, 11:17 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Actually, Tony recommended to me that I install my rear window before he did the cage as it might be a little difficult afterwards.
Oh, and I used the hardcore 3M stuff to put that window in, so it's not coming out without a fight (IMG:style_emoticons/default/laugh.gif) |
campbellcj |
Jun 15 2003, 11:25 AM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
It will certainly make it easier to paint the cage w/ the glass out. I found it nearly impossible to paint all the way around some of the tubes with the car fully assembled.
I was thinking about removing the heated rear window from my car and putting in lexan; I wonder if that's doable? |
machina |
Jun 24 2003, 05:08 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
we removed the rear window to pass the rear supports. This is permitted per the SCCA IT rules. They attach to folded plates at the forward part of the rear fender wells.
now we are fabricating a replacement lexan rear window to fit around the tubing. The bend in the tube was necessary to allow the lid to open on its original hinges. regards, dr (IMG:http://www.synthesisdv.com/images/rear tube.jpg) |
Lo-Fi Version | Time is now: 13th June 2024 - 07:03 AM |
