Single downdraft throttle cable mount., Solex throttle cable |
CatDaddy60 |
Mar 6 2016, 09:34 PM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
This is a call out to any of you that are running twin single downdraft carbs. I'm looking for a photo of how the throttle cable mounts. I'm piecing together a pair of Solex Pict 34s to get my car back on the road. Thank you for your help.
abes914 |
Mar 7 2016, 12:59 AM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
CatDaddy60 |
Mar 7 2016, 05:14 AM
Mark Henry |
Mar 7 2016, 07:09 AM
This is a call out to any of you that are running twin single downdraft carbs. I'm looking for a photo of how the throttle cable mounts. I'm piecing together a pair of Solex Pict 34s to get my car back on the road. Thank you for your help. (IMG:style_emoticons/default/huh.gif) Solex Pict 34? Or do you mean 34 PDIST? Solex Pict 34 is the late VW beetle carb and you on your own. 34 PDIST (-2,-3) is the Bus (van) carbs that is rear engine, if you are using the stock linkage you could cut the arm off the bottom and weld it back on top of the bar. That would make it pull mid-engine. Then you should just need a taller bracket mount for the cable much like on a hexbar linkage set-up. IIRC the 914 european 1.8 used stock carbs for a while, maybe you can find a pic of it's linkage in a search. |
Mark Henry |
Mar 7 2016, 07:18 AM
I should have have though of this, looking at the pic in this thread it looks like for the euro carb 914 they just swapped and put the carbs on backwards, linkage should work mid engine with that install.
http://www.914world.com/bbs2/index.php?showtopic=274513 (IMG:http://www.914world.com/bbs2/uploads/post-104-1453502375_thumb.jpg) |
Mark Henry |
Mar 7 2016, 07:24 AM
CatDaddy60 |
Mar 7 2016, 09:50 AM
Thank you for the link and the support. My twin brother used to run across the 40 single downdraft s while stationed in Frankfurt for the Airforce |
RonnieJ |
Mar 14 2016, 12:21 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
abes914 |
Mar 14 2016, 10:16 PM
[/quote]
That's the same way I installed my throttle cable for my dual Kadron 40's. [/quote] (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 11:59 AM |
