Need to Bleed, Both nipples on caliper? |
machina |
Mar 24 2005, 12:15 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
When doing a quick pre-track bleed, can we just bleed the top nipple? Seems like the air bubbles would move up, not down.
This is on a stock 914-4 setup. |
John |
Mar 24 2005, 12:22 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I would agree. Only the upper ones will typically let air out.
I used to open both when flushing the fluid. It seemed to go a little faster. I think they put both bleeders on so they could be either right or left. On "normal" cars, the bleeder is on top to let the air out. |
Dave_Darling |
Mar 24 2005, 02:32 PM
Quickie bleed or normal--just use the top bleeder valve. You can pump a gallon of fluid through the bottom bleeder of the caliper and not get the air out of it...
--DD |
Lo-Fi Version | Time is now: 9th June 2024 - 08:39 AM |
