Checking end play. Am I doing this right |
Amphicar770 |
Mar 15 2016, 08:19 PM
Senior Member Group: Members Posts: 1,197 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hi all,
Tonight I tried checking end play. Not sure if I'm doing it right and if my readings are good / bad. Engine has not been apart, flywheel has been refaced. I put flywheel on with 3 bolts, no grease seal, torqued to 40 ft lbs. Mounted gauge as shown. Took measurements at 3 points after rotating flywheel, all readings pretty consistent. Returns to zero when I pry in the other direction. Note that the gauge reading is going in reverse so it is actually reading approx 3 one thousandths. |
pilothyer |
Mar 15 2016, 08:43 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I would call that PERFECT !!!!
Amphicar770 |
Mar 15 2016, 09:06 PM
Thanks. Just re-positioned the gauge so that the contact point is closer to center of flywheel. Took some more readings. Pretty consistent. Whereas earlier readings were just to the low side of 3 one thousands, new readings are just to the high side.
stugray |
Mar 15 2016, 10:20 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Just to be clear: this is after you measured end-play with no shims, and have installed the shim pack right?
Cuz .003 with no shims would make me worry. |
Amphicar770 |
Mar 16 2016, 07:34 AM
McMark |
Mar 16 2016, 08:15 AM
Mark Henry |
Mar 16 2016, 10:09 AM
Good to go, don't forget the new flywheel Oring and you should install a new pilot bearing and fuzzy washer.
Lo-Fi Version | Time is now: 8th June 2024 - 08:30 AM |
