Trailing Arm Shaft ? |
Gear Drive |
Mar 17 2016, 09:31 AM
Newbie Group: Members Posts: 4 Joined: 17-March 16 From: Madison, Virginia Member No.: 19,766 Region Association: South East States |
I am in progress of restoring an ex-race car 914. Cleaning suspension parts and making a shopping list.
Trailing arm pivot shafts are both way less than smooth where the bushings contact the shaft. I am considering fabricating my own shafts from 4130 tubing, but before I order the stock to do that I wonder what others do? I cant seem to find any stock shafts available from the 'regular' suppliers, plenty of aftermarket suspension kits that include the shafts. I am planning on using bushings from PMB, and installing a 'zerk' fitting so having the urethane contacting the bare 4130 shouldnt be an issue when lubed (as in no chrome plating needed) I even have the option of making the wall thickness a bit thicker.... Any help appreciated, thanks to all. |
ChrisFoley |
Mar 17 2016, 09:36 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
AFAIK, I sell the only available replacement pivot shafts.
They can be found on my suspension webpage. Tangerine Racing |
914_teener |
Mar 17 2016, 09:41 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I have done mine exactly as you plan sans the 4130. Mine is set up with stock suspension. Had it this way for almost three years no issues.
Go for it. |
ConeDodger |
Mar 17 2016, 10:17 AM
Apex killer! Group: Members Posts: 23,611 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Eric Shea at PMB sent me some a few years back. Not sure where he gets/got them...
MikeM |
Mar 17 2016, 10:46 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
A couple of years ago I got some beauties from Bruce Stone.
Lo-Fi Version | Time is now: 7th June 2024 - 10:35 AM |
