Transmission reinstall., Any preventative maintenance? |
william harris |
Mar 27 2005, 07:23 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
OK, so if all goes according to plan, the motor and transmission should be ready to go back in the car this summer. The transmission shifted perfectly before the engine drop, even the linkage was good, shifting was absolutely spot on. So, before I mate the engine and transmission, is there anything I should do? Preventative maintenance? Suggestions? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
TravisNeff |
Mar 27 2005, 07:41 PM
If you haven't already, get a full gasket kit for the tranny and replace it all while you are in there. Replace the pivot cup bushing and check to make sure your throwout arm clearance is right (be it either adding or removing washer shims under the cup bushing pivot). Check the operating sleeve on the input shaft and throwout bearing operation. Other than that, check your mounts and then they flywheel side of the engine.
jwalters |
Mar 27 2005, 07:49 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Here is something--About the bands needing good grip--I have read allot about staying away from synthetics--what about pouring some GM limited slip friction modifier in as well??? Would it help out any on bands that are not too far away gone yet??
Lo-Fi Version | Time is now: 6th June 2024 - 12:04 PM |
