Engine wire question - AAR & Oil Pressure connector |
Amphicar770 |
Apr 1 2016, 09:11 PM
Senior Member Group: Members Posts: 1,198 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hi All,
As shown, the engine has cleaned up nicely and everything is just about back on. A few gaps in photos, notes, or memory but not too bad. Finishing up the wiring harnesses this evening. Question I have regards the wire that comes from the bottom of the AAR valve (it is red wire in photo with single spade connector). Where does that attach to. Similar question regarding what I think is the oil pressure switch (the one right by the oil cooler). What wire connects to that? Thanks, Mike |
boxsterfan |
Apr 1 2016, 09:41 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
http://bowlsby.net/914/Classic/zTN_Elect_12-pinConnector.jpg
Should be a white wire on the harness coming off of the 12-pin connector from the relay board for the AAR. On my 74 2.0L, this white comes off of the harness from the passenger side. For the oil pressure sender, it should be green/red stripe again coming from the same harness that comes off the 12-pin connector on the relay board. |
ClayPerrine |
Apr 2 2016, 08:09 AM
Life's been good to me so far..... Group: Admin Posts: 15,523 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Looking at your picture, someone put a new wire on the AAR. It attaches to the white wire in the harness.
Amphicar770 |
Apr 2 2016, 08:30 AM
Thanks. That did the trick. The two wire from the harness were positioned incorrectly. Once you guys provided the info it was a "doh" moment!
Lo-Fi Version | Time is now: 10th June 2024 - 04:24 PM |
