Throwout bearing grease |
Amphicar770 |
Apr 5 2016, 04:53 PM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I was looking into proper grease for throw out bearing and shaft. Came across this grease from Honda, made just for such applications. Figured I would share.
Genuine Honda 08798-9002 Urea Grease https://www.amazon.com/dp/B00BFDFYKW/ref=cm...d_7aebxb18R79J6 |
914Sixer |
Apr 5 2016, 05:55 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I used a little high temp wheel bearing grease.
Mark Henry |
Apr 5 2016, 08:47 PM
I was looking into proper grease for throw out bearing and shaft. Came across this grease from Honda, made just for such applications. Figured I would share. Genuine Honda 08798-9002 Urea Grease https://www.amazon.com/dp/B00BFDFYKW/ref=cm...d_7aebxb18R79J6 Urea is the component of pee....not shitting you...urea urine. Most grease uses soap as part of the base, Swepco 101 is lithium base. this is urea base. Soap based grease flow at lower temps, the lithium or urea is higher temp. BTW never thought about a urea grease, but I did now the urea is used heavily in cosmetics. Kiss a girl with lots of make-up on and you are kissing pee. (IMG:style_emoticons/default/happy11.gif) |
6freak |
Apr 6 2016, 08:30 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I was looking into proper grease for throw out bearing and shaft. Came across this grease from Honda, made just for such applications. Figured I would share. Genuine Honda 08798-9002 Urea Grease https://www.amazon.com/dp/B00BFDFYKW/ref=cm...d_7aebxb18R79J6 Urea is the component of pee....not shitting you...urea urine. Most grease uses soap as part of the base, Swepco 101 is lithium base. this is urea base. Soap based grease flow at lower temps, the lithium or urea is higher temp. BTW never thought about a urea grease, but I did now the urea is used heavily in cosmetics. Kiss a girl with lots of make-up on and you are kissing pee. (IMG:style_emoticons/default/happy11.gif) Polyurea.. (IMG:style_emoticons/default/lol-2.gif) theres only a capitil P in it |
dcheek |
Apr 6 2016, 01:55 PM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
This is what I used last week. Made by Sachs. There is usually a packet enclosed with the clutch and pressure plate. I bought a whole tube from Pelican.
Dave |
Amphicar770 |
Apr 6 2016, 02:09 PM
Polyurea greases are almost always chosen because of their high temperature properties.
Art Polishuk, in his tome, A Brief History of Lubricating Greases, claims that “one of the unique properties of polyurea greases is that they tend to thicken with an increase in temperature. This may contribute to their long performance in bearings at elevated temperatures. Their long bearing life may also be due to the fact that they contain no metals to catalyse oxidation”. Another reason for the choice of a polyurea grease may be for specific rheological properties where some versions exhibit extreme thixotropic behaviour and can be made mechanically instable by design. Polyurea greases represent some 4% of the total worldwide grease production. They are most popular in Japan whereas, in other areas, they have not caught on signi cantly, most probably due to the health and safety issues concerning the handling of the raw materials. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:39 PM |
