Bearing like noise at left rear suspension |
914itis |
Apr 16 2016, 07:22 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I have a noise on the left rear suspension that sounds like a bearing but it's not .
I checked the wheel for play , there is none, I swapped the tires, no change , brakes are new proper clearance set , rotors are new. The noise seems to come at all rpms , all gears when I hit 70 mph. Any help appreciated . |
okieflyr |
Apr 16 2016, 07:30 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I had a similar noise at one time and it turned out to be a small stone wedged in a brake pad joint. I hope yours is as simple.
rgalla9146 |
Apr 17 2016, 09:48 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I once changed a rear wheel bearing on a 930 only to find out it was worn tires. |
914itis |
Apr 17 2016, 10:16 AM
Ties are good , I even swapped them to make sure .
Geezer914 |
Apr 17 2016, 12:01 PM
Geezer914 Group: Members Posts: 1,436 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Jack the car up and spin the wheel. You will hear it grinding if the bearing is bad. Also grab the tire at 3 & 9, then 6 & 12, and check for any play.
914Mike |
Apr 17 2016, 12:19 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
CV Joint?
Wheel bearings usually have some play when they start getting noisy. |
rjames |
Apr 17 2016, 03:08 PM
I'm made of metal Group: Members Posts: 3,949 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Does it go away when turning left or right? If yes likely the bearing. Fix it and inspect the CVs as that's a good time to do it. Both jobs really suck. (IMG:style_emoticons/default/biggrin.gif)
914itis |
Apr 17 2016, 06:25 PM
Non play on wheel , no noise when making turns, I have a feeling that it is the CV.
Rockaria |
Apr 18 2016, 02:33 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
I had the exact same problem. Turned out it was my CV joints. I was able to add grease to the joints without removing them from the car. I squirted grease past the rubber seal. I then massaged the grease with the rubber cover to get grease into the small areas.
Three years later I still have no noise and the car drives perfectly. I even have a new set of joints an bearings ready to go when its time for a full rear end rebuild. But for now it is working perfectly. Non play on wheel , no noise when making turns, I have a feeling that it is the CV. |
djway |
Apr 19 2016, 02:37 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I had the same noise especially when turning left. Changed the bearings both sides, no change. A mechanic friend said it was on the right side and I argued it was left as the angle increased. It wound up being a loose CV on the outboard drivers side. One broken bolt and the rest were loose. The inner spider showed metal fatigue in several spots.
Well on the good side everything in the rear has been replaced or serviced and it has no more noise (IMG:style_emoticons/default/smile.gif) |
malcolm2 |
Apr 19 2016, 07:54 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I love taking things apart. This video from Van is perfect. If you remove the axle you think is noisy (after you check for CV bolt tightness), you can follow part 1 and part 2 of Van's videos and you will find a worn, pitted spider, or broken cage or something.
If you are not on a strict budget, buy 2 joints from Tangerine and install them. While you wait on shipping you can spiff up the half shaft. If you do have a strict budget, you can probably find a few guys here that will help find a replacement for the worn part. Have fun and get some gloves. (IMG:style_emoticons/default/piratenanner.gif) https://www.youtube.com/watch?v=LsytyVzokBg and part 2 (the re-assembly): https://www.youtube.com/watch?v=KOma2BMhrzc |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:33 AM |
