Sand or Media Blasting, for rusty trailer |
jfort |
Apr 19 2016, 09:37 AM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I know there are lots of discussions about rust on this site, but I can't find what I am looking for using the Search tool. Bear with me.
I need to clean up rust, and then paint, a car hauler trailer. I have an air compressor. I see siphon and gravity feed types. What is preferred? Is there a type that will make it go faster/easier? Also, what blasting material should I use and where does one procure that? All at Harbor Freight? I wire brushed, primed and painted plenty of rust on ships in the Navy, but using a blaster is new to me. Thanks! |
PanelBilly |
Apr 19 2016, 10:03 AM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Take it to a shop that specializes in it. It's a messy job and they make it easy.
Mark Henry |
Apr 19 2016, 11:35 AM
You need a BFC ...big fuching compressior, my 5 hp barely keeps up with a little sandy jet blaster.
If you do go this route I'd do as much as you can with a wire wheel on a grinder first. I have to do the same job soon on my trailer. |
brant |
Apr 19 2016, 12:07 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Also, you don't really want to use sand...
silica in the lungs is really really bad the media made for blasting is actually silica free google it and you will decide its well worth the trip to the tractor supply store for a 12$ bag of media |
Amphicar770 |
Apr 19 2016, 01:20 PM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Do not use sand, very bad for your health.
Probably want something like aluminum oxide which is more aggressive. Glass bead and such is more for thinner metals where you are worried about warping or penetrating the metal. I agree with PanelBilly. For something big like a trailer, it is often best to outsource it. I have had entire cars done for a few hundred $$$. If you must DIY then try Northern Tool or TP Tools. Something like this. http://www.northerntool.com/shop/tools/pro...36724_200136724 |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:57 AM |
