oil cooler, any way to test it? |
joeav8tor |
Mar 30 2005, 07:03 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
hi guys,
I dropped my motor to do some preventative maintenance, and have been cleaning 32 years of oil from the motor and tranny...I found the oil pressure sensor to be leaking and ordered a new one...there was a good bit of oil under the motor, I dont know if the oil was from the oil pressure sensor, or from the oil cooler...there was some oil residue from the bottom corner of the cooler near the jug. Is ther any way to test the oil cooler...thinking about putting oil cooler seals in as a minimum...thanks Joe (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) |
Bleyseng |
Mar 30 2005, 07:12 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Atleast put new oil cooler seals in! Yes, you can take the oil cooler in to have it tested and cleaned or install a new one if its really junked up from old oil varnish. It can't do the job right if its crappy inside.
I havent had too much luck trying to clean it myself as I want it spotlessly clean. Geoff (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Type 4 |
Mar 30 2005, 11:55 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
You can buy one of these to test your cooler. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
Bleyseng |
Mar 31 2005, 09:07 AM
Normally they don't leak but oil coolers can get all kinds of shit stuck in them.....if its questionable buy a new one and run cooler.
Geoff (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
tat2dphreak |
Mar 31 2005, 09:52 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
when I installed my engine I had 2 oil coolers, I soaked both of them in paint thinner, and pumped a can of carb cleaner through each... then tested the pressure with air... one worked great, one was still kinda plugged... but you can clean them out pretty good like this... if you want... but in retrospct, I probably should have just bit the bullet and paid the $150 (or what ever it was) and got a new cooler...
Lo-Fi Version | Time is now: 23rd May 2024 - 11:00 AM |
