"74 bumpers |
"74 bumpers |
danger |
Apr 19 2016, 06:20 PM
Newbie Group: Members Posts: 7 Joined: 6-February 16 From: San Diego, CA Member No.: 19,644 Region Association: Southern California |
Hi, new here, I am sure this has been covered somewhere, but how do you take off the bumpers on a '74? Thanks
somd914 |
Apr 19 2016, 06:26 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Hi, new here, I am sure this has been covered somewhere, but how do you take off the bumpers on a '74? Thanks For the front, inside the wheel wells you will see two bolts in each wheel well. Take them out and off comes the bumper. I find turning the wheels to gain more clearance helps. Very similar on the rear - you will see two bolts on each side above the valence in each wheel well. |
EdwardBlume |
Apr 19 2016, 07:32 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
It helps to start it with your long 13MM socket and then hold up the bumper and turn the screws by hand. Have an assistant help hold it up so it doesn't come off on you...
9fourteen14 |
Apr 19 2016, 09:04 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
Hi, new here, I am sure this has been covered somewhere, but how do you take off the bumpers on a '74? Thanks i found the bumper tops was what i had a question. search for my post i posted a few bumper top pictures. and how to take them off.. should be enough for you. what are you gonna do with them? good luck BTW: I also have a 74 2.0 djet all original |
danger |
Apr 19 2016, 10:28 PM
Hi, new here, I am sure this has been covered somewhere, but how do you take off the bumpers on a '74? Thanks For the front, inside the wheel wells you will see two bolts in each wheel well. Take them out and off comes the bumper. I find turning the wheels to gain more clearance helps. Very similar on the rear - you will see two bolts on each side above the valence in each wheel well. Have done that with the front so far, but it seems to be still firmly in place, I thought maybe there were more connections. Maybe there is a little rust holding in place or?? |
danger |
Apr 19 2016, 10:30 PM
Hi, new here, I am sure this has been covered somewhere, but how do you take off the bumpers on a '74? Thanks i found the bumper tops was what i had a question. search for my post i posted a few bumper top pictures. and how to take them off.. should be enough for you. what are you gonna do with them? good luck BTW: I also have a 74 2.0 djet all original ....Going to get the car painted. |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:10 AM |
