> Different year rear calipers, the same?
LukeD
post Mar 30 2005, 10:53 PM
I have a 70 with original calipers, I am going to send them to Eric Shea next week. My question is, I have a 75 parts car and I would like to keep my 70 semi drivable sooooo, can I send the 75 calipers to Eric and then when I get them back will they bolt right on to the 70? Also, Pelican sells those "Speed Bleeder Valves" are they highly recommended?
Or should I invest in one of those $45 power bleeders?
Luke D
Replies(1 - 5)
Dave_Darling
post Mar 30 2005, 11:03 PM
914 Idiot
IIRC they are not identical, however they can be mixed-and-matched with no problems. The only difference I think is that the early has top and bottom bleeder valves while the late only has the top ones. Or I may have that backwards.
Speed bleeders are recommended by a number of people who have them. I haven't installed mine yet... Other folks like the power bleeder. Some sickos probably have both. (At least one really sick person has both speed bleeders and a power bleeder and has yet to use either of them.)
--DD
Rusty
post Mar 31 2005, 05:16 AM
I have both, and much prefer the speed bleeders. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
-Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
SLITS
post Mar 31 2005, 07:26 AM
"This Utah shit is HARSH!"
Early '70-Mid '73....single bleeder top
Late Late '73 - "76.....dual bleeders, but no one has determined the need for the bottom bleeder (maybe flushing the system)
Functionality....the same
Production rebuilders drill the single bleeders for the bottom bleeder, but they don't really know why.
davep
post Mar 31 2005, 08:07 AM
914 Historian
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
There are some internal differences also, however they are functionally the same. No problem in mixing the calipers.
My belief is that draining the calipers during bleeding is a good idea. Flush fluid from the reservoir to each caliper to ensure fresh fluid is at each caliper. Then drain to get all the old fluid out; otherwise old fluid will remain inside the pistons, particularly on the outboard side. You have to realize that the fluid inlet and bleed nipples are very closely coupled. The fuild will take the shortest path, and that does not include the outer caliper half at all. A simple bleed will never change the fluid in the outer caliper half. The adjuster mechanism in the calipers does an excellent job of trapping old fluid. Only by removing the pistons and rinsing with alcohol can you do a perfect job. Just like stale gas can ruin an engine, so can old fluid ruin a caliper. While this may be critical for racers, a complete job every few years for a street car is adequate.
LukeD
post Mar 31 2005, 11:16 AM
Thanks for the great info, I have decided to send Eric the ones off my 75 parts car.
Luke D
- Lo-Fi Version Time is now: 1st July 2025 - 07:16 AM
