74ravenna |
Member ![]() ![]() Group: Members Posts: 472 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States ![]() ![]() |
Hi,
Can the pushrod tubes and oils seals be replaced from underneath with the engine still in the car? It looks like if I took off the exhaust I might have enough room? Thanks all. Steve |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
No, I don't think so. You have to lower the engine.
Why do you want to take the pushrods out? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Yes it can be done .... not that hard. I've done it a couple of times.
I don't remember if I removed the HE or not. Once you remove the rocker assemblies, you can get the pushrods out. When removing the rocker assemblies from the head, I use 5/16" bolts to hold the assemblies together. Push them through when sliding the rocker assemblies off the studs. Removing the pushrod tubes without crushing them can be a problem. I used a pair of channel locks to twist and pull. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
yes you can.
You need to pull the rocker covers, then the rockers. Then you can pull each pushrod tube out and tip it in place to replace the seals. At that point you can get the push RODs out. You cannot completely remove the pushrod tubes. Some of them (maybe all) will hit the suspension ear. But you CAN replace all of the seals without removing the tubes completely. |
EdwardBlume |
yes you can. You need to pull the rocker covers, then the rockers. Then you can pull each pushrod tube out and tip it in place to replace the seals. At that point you can get the push RODs out. You cannot completely remove the pushrod tubes. Some of them (maybe all) will hit the suspension ear. But you CAN replace all of the seals without removing the tubes completely. There you go. Thanks for the correction. I tried a long time ago to pull the rod out without the tubes coming out, so now I know. Thanks. |
74ravenna |
No, I don't think so. You have to lower the engine. Why do you want to take the pushrods out? I'm getting a lot of oil leaking by. The car hadn't been started in 33 year but its running now and what was a small leak seems to have gotten much worse. Its dripping onto the exhaust to the point where its starting to smoke. I think some is also from the valve cover but it appears to be really bad at the end of the push rods. So can i just replace the seals? Thank again. |
SLITS |
No, I don't think so. You have to lower the engine. Why do you want to take the pushrods out? I'm getting a lot of oil leaking by. The car hadn't been started in 33 year but its running now and what was a small leak seems to have gotten much worse. Its dripping onto the exhaust to the point where its starting to smoke. I think some is also from the valve cover but it appears to be really bad at the end of the push rods. So can i just replace the seals? Thank again. Yes, get the Viton (brown?) seals. |
74ravenna |
yes you can. You need to pull the rocker covers, then the rockers. Then you can pull each pushrod tube out and tip it in place to replace the seals. At that point you can get the push RODs out. You cannot completely remove the pushrod tubes. Some of them (maybe all) will hit the suspension ear. But you CAN replace all of the seals without removing the tubes completely. Ok, so theres my answer on the seal replacement. Thanks RobW, stugray and SLITS. Steve |
Lo-Fi Version | Time is now: 4th July 2025 - 08:29 PM |
