Lemfoerder turbo tie rods, Do I need to order the washer |
Gearup |
Apr 23 2016, 03:26 PM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Gents,
I am about to purchase Lemfoerder turbo tie rods for my build. I am going to buy the the boots separate from them and am curious if I need to buy the washers. I can't remember what came off with the stock 914 tie rods and if they did have washers are the compatible with the turbo tie rods. Thanks. |
ThePaintedMan |
Apr 23 2016, 03:37 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Order them. There has been some debate on whether different years of racks require them or not - but if you don't order them, but need them, you'll be stuck. They're not that expensive.
Gearup |
Apr 23 2016, 03:39 PM
TheCabinetmaker |
Apr 23 2016, 06:07 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
To my recollection, the boots and washers come with the kit.
ConeDodger |
Apr 23 2016, 06:13 PM
Apex killer! Group: Members Posts: 23,608 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I don't recall what does and does not come with the kit, but I do recall the difference before and after! (IMG:style_emoticons/default/aktion035.gif)
TC 914-8 |
Apr 23 2016, 10:57 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Order them. There has been some debate on whether different years of racks require them or not - but if you don't order them, but need them, you'll be stuck. They're not that expensive. Thank very much Sir If you order from pelican parts they include them in their kit. Also order the bump steer washer kit for $12.00 or so. I just installed the whole kit and enhanced my steering No wheel shimmy and my steering is tighter than ever!!! |
r_towle |
Apr 24 2016, 06:54 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You do not use the large washer on the rack end when installing turbo tie rods or you won't be able to thread in the fitting enough.
No debate on that fact. There is zero difference in the racks at the tie rod end, or bushings and fittings. The only difference in racks from early to late is the pinion gear assembly. the thick washer gets tossed in the trash. This is a safety issue, so please use common sense and look at the setup versus reading online forums. It must be threaded in enough to be safe. The washer has no purpose in a 914 application. The boot mounts without it. You will not be able to adjust your toe in enough when using the washer. Rich |
ThePaintedMan |
Apr 24 2016, 07:04 AM
Sorry Rich, I guess I remembered wrong. So that washer was only for 911 applications?
r_towle |
Apr 24 2016, 07:07 AM
Turbo tie rods are a 911 part.
The kit comes with parts for a 911 (sorry, not sure what year 911) For the 914, due to both geometry and safety, the washer is not used. Rich |
mepstein |
Apr 24 2016, 07:12 AM
914-6 GT in waiting Group: Members Posts: 19,308 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Don't 914's/914-6's have the same front geometry as a 911.
r_towle |
Apr 24 2016, 07:25 AM
Try adjusting the toe with a washer....it will be toe out...
ThePaintedMan |
Apr 24 2016, 07:49 AM
There must be a difference in track, or a difference on at least the 930 Turbo, for which these were designed.
ctkellett |
Apr 24 2016, 08:07 AM
Newbie Group: Members Posts: 12 Joined: 18-February 15 From: PA Member No.: 18,450 Region Association: None |
Try adjusting the toe with a washer....it will be toe out... I am confused, if the washer does not allow enough adjustment wouldn't that mean it would be toe in, not out? If it was toe out, you would just dial in more threads, right? I am in the middle of doing replacement this so that is why it is fresh on my mind. The stock kit that I took off of the car had a large treaded washer between the rack and tie rod arm that was fairly close the the thickness of the washer that came in the new turbo tierod kit from pelican. The threading on the rack side of the tierods are not threaded all the way down to the base so they will need some sort of spacer anyway I am guessing then? |
Lo-Fi Version | Time is now: 4th June 2024 - 04:42 AM |
