Distributor Vacuum Question /6 2.7l |
tornik550 |
Apr 23 2016, 07:20 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently built a 2.7 /6. I am getting the final details worked out. I have modified zenith carbs. I am using E cams cause I am going more for lower end torque. Anyway- I have a 2.7l distributor which has a vacuum advance. The carbs have been modified and have the vacuum ports plugged. I can unplug them if needed. Do I need to hook up the vacuum advance on the distributor? If I don't, what ill effects will I notice? My car is setup for spirited street driving.
I know very little about vacuum advance distributors. My previous engines did not have them. I am finding a lot of conflicting information. |
colingreene |
Apr 23 2016, 07:28 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Really you dont want to run that distrubtor at all.
you have so much throttle area that the slightest movement of the throttle pedal will drop all vac. What you want is something that is entirely mechanical or crank fire. The best thing you can do if you insist on running it is, hook up all the vac lines to a manifold then feed a vac signal straight to the distributor. |
patssle |
Apr 23 2016, 07:40 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
You can have the the vacuum advance removed and the distributor recurved for carbs and rebuilt. That'll give you even better throttle response and performance. But it's costly.
This guy is probably the best (and he did mine) but $$$$: http://flat6recurve.com/ |
PanelBilly |
Apr 23 2016, 07:45 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Had mine done by Jerry Woods. Price was reasonable and it was done quickly
porschetub |
Apr 23 2016, 11:23 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had mine done by Jerry Woods. Price was reasonable and it was done quickly True billy its not rocket science you need a dizzy tester and the knowledge to change to the right advance springs and that's what JW has been doing for decades. Have just purchased 2.4T one and that's easy cause the vacuum advance is actually a 10 degree retard and can be removed...done and dusted for me ,next job is to strip it and clean it. |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:07 AM |
