R side emergency brake cable routing (914-4), As above |
Rleog |
Apr 25 2016, 09:45 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
Cable attaches via screw clip to a boss on the underside of the firewall to the left of the center tunnel. Then how does it go in relation to the cables and wires around the center tunnel exits? How does it pass along the R suspension arm?
Thanks |
ChrisFoley |
Apr 25 2016, 09:54 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Cable attaches via screw clip to a boss on the underside of the firewall to the left of the center tunnel. Then how does it go in relation to the cables and wires around the center tunnel exits? How does it pass along the R suspension arm? Thanks It goes below all the cables at the center of the tunnel. There should be a couple of clamps to secure it to the pinch weld. |
jkb944t |
Apr 25 2016, 10:28 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Rleog |
Apr 25 2016, 10:42 AM
Cable attaches via screw clip to a boss on the underside of the firewall to the left of the center tunnel. Then how does it go in relation to the cables and wires around the center tunnel exits? How does it pass along the R suspension arm? Thanks It goes below all the cables at the center of the tunnel. There should be a couple of clamps to secure it to the pinch weld. Thanks. Slow, as always, but much more fun putting it back together than tearing it apart. Still a ways away but hoping you'll take it back once I get the engine back in it. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:26 AM |
