GB Fuel line grommets 10mm and 8mm Correct "stopper" shape, Cary made me do it, well I needed them too $4 each |
Mikey914 |
Apr 28 2016, 12:44 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just finished the fuel line grommets for the fire wall area. Both are done, but I have a few other items that are done that I want to put up too so it may be a day or two as we wrap these up.
$4 a pop I'm going stainless on my lines and will do 10mm for both, but figures there would be those that wanted the correct ones for the OEM application. I have test fitted these on my Cary's car and they are a nice fit. The material is silicone so that it will make a great seal and are just slightly softer than the OEM to make them easier to install. So let me know who's up for some? Attached image(s) |
marksteinhilber |
Apr 28 2016, 11:07 AM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Just finished the fuel line grommets for the fire wall area. Both are done, but I have a few other items that are done that I want to put up too so it may be a day or two as we wrap these up. $4 a pop I'm going stainless on my lines and will do 10mm for both, but figures there would be those that wanted the correct ones for the OEM application. I have test fitted these on my Cary's car and they are a nice fit. The material is silicone so that it will make a great seal and are just slightly softer than the OEM to make them easier to install. So let me know who's up for some? I'm ready for some. I guess I'll need two of the 10mm and two of the 8mm for my project car. How soon will they be made? Tell me what I need to do to order and pay. Mark S. |
BillC |
Apr 28 2016, 11:34 AM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Good timing, I'm almost ready to install my new stainless fuel lines. So, I'll need a set too. How many are needed? One of each or two of each?
914_tinker |
Apr 28 2016, 02:39 PM
Newbie Group: Members Posts: 10 Joined: 15-December 14 From: Columbia, Tn Member No.: 18,225 Region Association: South East States |
I'll take a set. Thanks
Mikey914 |
Apr 28 2016, 02:55 PM
ThinAir |
Apr 28 2016, 05:18 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
How about the oval grommets for passing the fuel hoses through sheet metal under the battery tray?
Silver Surfer |
Apr 28 2016, 05:25 PM
Not done yet. Group: Members Posts: 134 Joined: 25-July 06 From: Portland, OR Member No.: 6,507 Region Association: Pacific Northwest |
I'll take a 10mm set and an 8mm set as I haven't decided yet.
ChrisFoley |
Apr 28 2016, 07:05 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Mikey914 |
Apr 28 2016, 07:14 PM
Yes if you are talking about the oblong one that is as a 45 degree angle I just brought some in. I am working on the grommet at the drivers firewall for the charcoal canister currently.
sbsix |
May 4 2016, 04:21 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 451 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
I'm in for a set of 8mm and 9.5mm.
sbsix |
ThinAir |
May 4 2016, 05:41 PM
relentless |
May 4 2016, 07:18 PM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
I'd like a set. How many are needed?
ThinAir |
May 5 2016, 02:08 PM
Mikey914 |
May 5 2016, 08:26 PM
How about the oval grommets for passing the fuel hoses through sheet metal under the battery tray? Still haven't found these on the 914rubber.com site. Would love it if someone has a link. These will be up on Monday, if not earlier. |
Mikey914 |
May 9 2016, 12:21 AM
Got these up on the site right here -
10mm http://shop.914rubber.com/Fuel-line-gromme...m?categoryId=-1 8mm http://shop.914rubber.com/Fuel-line-gromme...m?categoryId=-1 The original configuration calls for a 8mm and a 10mm grommet. The picture shows both grommets with a 10mm on the stainless line. Again only one 8mm grommet is included for this selection I did this as individual parts rather than a kit so if you were doing stainless lines and opted to do both in 10mm, you could simply order what you want. PM's going out to all who responded |
Lo-Fi Version | Time is now: 1st June 2024 - 06:03 PM |
