Another L-Jet question, AAV related |
Rob-O |
Apr 28 2016, 11:32 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Does anyone have a pic of the AAV in it's mounted position? I understand where it goes (driver's side, just in front of the air plenum). My AAV has a built in boss on it with two holes (like every L-Jet AAV I've seen), but I can't figure out for the life of me if that boss connects to some type of mount, or if the boss is used to mount the AAV directly to the engine tin/engine.
RohJay |
Apr 29 2016, 04:58 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
Hope this helps:
Rob-O |
Apr 29 2016, 05:31 AM
Thanks!
Okay, so I get the exact orientation, but is it just screwed/bolted to the tin? Kind of looks that way in the pic but it's difficult to tell conclusively. |
Rob-O |
Apr 29 2016, 07:52 AM
I tried putting the AAV on the engine in that spot and facing that direction, but unless there is a mount I'm missing (completely possible as my tin isn't a 1.8L tin) the AAV won't fit there.
I only see one screw holding down the tin in that spot. If I used the screw to hold down the AAV, the vacuum hose on the short side of the AAV wouldn't fit because the hump of the tin over the cylinder bank would be in the way. Pics below... Attached thumbnail(s) |
RohJay |
Apr 30 2016, 05:55 AM
The pic I sent earlier was something I received from a member here, when I was trying to figure out the same.
I just checked my own now: Looks like the AAR valve is mounted on the tin with self tapping screws. Be warned my L-Jet system was also retro fitted... and hoses might not be original shape Attached image(s) |
ClayPerrine |
Apr 30 2016, 06:42 AM
Life's been good to me so far..... Group: Admin Posts: 15,519 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I don't have a picture, but here is a clip from PET.
It mounts between the engine tin and the centerline of the case. |
Dave_Darling |
Apr 30 2016, 09:54 AM
Cool, I didn't know about that part!
My old 1.8 was an early one, and had a 1.7-style AAR. I believe it mounted to a bracket coming off of the plenum, but I don't remember that clearly. --DD |
bretth |
Apr 30 2016, 10:22 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Rob-O |
I don't have a picture, but here is a clip from PET. It mounts between the engine tin and the centerline of the case. Wow, thanks Clay. I looked the PET over pretty well and missed that. I usually go there before I start asking a ton of fitment questions. In this case I heard conflicting info. I had heard (like Dave) that it was mounted to the plenum and you had said there was a mount. My throttle body should be here tomorrow. As far as I can tell, the plenum with the TB attached looks like it should be the first piece to go on. Then the AAV and the Thermo-time. Then lay out the FI harness and the engine electrical harness. Then the runners and other bits. I already have the injectors, elbows, new clamps and fuel rails attached to the runners. |
ClayPerrine |
May 1 2016, 05:45 AM
I am going out to the garage shortly. I will look for the AAR bracket for you.
Clay |
Rob-O |
May 1 2016, 06:45 AM
Thanks Clay. I'm watching the kids today but we could make the trip up for a field trip.
ClayPerrine |
May 1 2016, 12:16 PM
I have the bracket. It is in the parts cleaner for you.
Do you still need the fuel pressure regulator bracket? Clay |
Rob-O |
May 1 2016, 01:59 PM
Yes on the fuel pressure regulator bracket.
Lo-Fi Version | Time is now: 9th June 2024 - 06:25 AM |
