And now the fuel pump?, It's always something |
iankarr |
Apr 29 2016, 10:57 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
I finally get the ignition module replaced and the engine fires up! I (definitely) turn off the car, go grab a beer and come back in half hour to begin tuning the carbs and it won't turn over. Doesn't seem to be fuel getting to the carbs. And I don't hear the fuel pump whine with the key in the "on" position before starting. I swapped the relays around on the board, but no luck. I assume the pump is dead. Or do you guys have any other suggestions? Thing is...the PO relocated the pump...I guess to the front cause I can't find it anywhere else. I can't see it through the hole under the tank or from the top. Anything else I should try before pulling the tank??? If I do need a new pump, is there a low pressure one you recommend that I can pick up at a FLAPS? UGHHHHH! Thanks! |
Spoke |
Apr 30 2016, 05:19 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I think I used Mr Gasket 12S.
Rob-O |
Apr 30 2016, 03:48 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Is the battery still charged? If so an no cranking, I'd seriously suspect the ignition switch (you called it a module but I'm assuming you mean the switch) you just replaced.
steuspeed |
Apr 30 2016, 05:37 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Try this trick. Take a relay apart and then press the relay with your finger while the key is on. See if the pump runs. The stock pump is under the passenger side just in front of the rear wheel. It's tucked up in there. You can get 12V on the pump with a couple wires too. My pump just died too after running fine. The car has been sitting a while. After exercising all the relay sockets and wire connections it came back to life.
steuspeed |
May 6 2016, 07:32 PM
Any luck with the fuel pump?
iankarr |
May 6 2016, 09:41 PM
K...this is really weird. Seems at least a full page of posts to this thread are gone.
Bottom line is that I figured out that it was a relay after all. All good! Sir Andy... What do you think happened to the other posts? |
Lo-Fi Version | Time is now: 9th June 2024 - 05:26 PM |
