| orbit398 |
May 2 2016, 08:04 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
Does anyone have any suggestions for replacement speakers for a 1974 model original location. I purchased some from Crutchfield (MTX Audio Coaxial Thunder 68) but they don't fit. thanks
| malcolm2 |
May 2 2016, 08:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,757 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Does anyone have any suggestions for replacement speakers for a 1974 model original location. I purchased some from Crutchfield (MTX Audio Coaxial Thunder 68) but they don't fit. thanks Speaker pods from 914 rubber work great. You can cut them to fit many different speakers. They look close enough to OEM and take a round speaker, maybe a 7". just remember to order the speaker grills when you order speakers and use them vs. the brittle OEM. The OEM pods are designed for some funky size 5x7 iirc. no such hole pattern in this century either. http://shop.914rubber.com/Porsche-914-door...m?categoryId=-1 |
| porschetub |
May 3 2016, 02:00 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,196 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Does anyone have any suggestions for replacement speakers for a 1974 model original location. I purchased some from Crutchfield (MTX Audio Coaxial Thunder 68) but they don't fit. thanks Speaker pods from 914 rubber work great. You can cut them to fit many different speakers. They look close enough to OEM and take a round speaker, maybe a 7". just remember to order the speaker grills when you order speakers and use them vs. the brittle OEM. The OEM pods are designed for some funky size 5x7 iirc. no such hole pattern in this century either. http://shop.914rubber.com/Porsche-914-door...m?categoryId=-1 OP asked about original location,tricky cause they aren't 5 x 7,been there done all that and got frustrated and at a cost,modern speakers don't fit because the magnets are generally too large and won't clear the heater tube hoses. Not a lot of choices for fit in the original enclosures if you want a reasonable sound. |
| orbit398 |
May 3 2016, 08:02 AM
Found some direct replacements at Auto Atlanta
RGS246 914 200 WATT, 2-WAY 4X6 STEREO SPEAKERS, PAIR $39.50 |
| napasteve |
May 3 2016, 09:14 AM
914 driving winemaker ![]() ![]() ![]() Group: Members Posts: 529 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California
I would be interested to know if the AA speakers actually fit in the original holders. Assuming they do fit, I'd be interested to know if there is anywhere else besides AA that they could be purchased.
| malcolm2 |
May 3 2016, 09:41 AM
Speaker pods from 914 rubber work great. OP asked about original location, So where do you think the 914rubber pods go? They replace the brittle, funky shaped Factory enclosures. ![]() or do you think the speakers originally came in the door? |
| rjames |
May 3 2016, 10:13 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,485 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Speaker pods from 914 rubber work great. OP asked about original location, So where do you think the 914rubber pods go? They replace the brittle, funky shaped Factory enclosures. ![]() or do you think the speakers originally came in the door? I think he meant speakers in the original location- as in the original plastic pods/covers, not in an aftermarket pod. |
| 23e Heure |
May 3 2016, 10:22 AM
Busy overtaking 911s ![]() ![]() Group: Members Posts: 323 Joined: 13-August 15 From: London Member No.: 19,057 Region Association: England |
| orbit398 |
May 3 2016, 10:31 AM
I would be interested to know if the AA speakers actually fit in the original holders. Assuming they do fit, I'd be interested to know if there is anywhere else besides AA that they could be purchased. Hope they fit perfect. They don't cost much either. Not interested in big sound as I have the original radio. Just wanted it stock so I am sure these will work fine. |
| jeffdon |
May 3 2016, 10:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I have been thinking that there are a ton of little speakers that put out great sound (think Blue tooth boomboxes). Seems like it would be easy to find some really good little drivers and adapt them to the factory pods. With maybe a base unit under the dash?
| napasteve |
May 3 2016, 01:26 PM
I looked at the AA item and did a bit of googling and it turns out that AA is selling the Sound Storm Laboratories GS246 Gs Series 4X6" 2-Way Speaker 200W. It's available on eBay and Amazon.
I still wonder if it will fit in the factory pods. Orbit398, if you do get them, please let the community know if they fit. Thanks. |
| porschetub |
May 3 2016, 01:43 PM
Speaker pods from 914 rubber work great. OP asked about original location, So where do you think the 914rubber pods go? They replace the brittle, funky shaped Factory enclosures. ![]() or do you think the speakers originally came in the door? I think he meant speakers in the original location- as in the original plastic pods/covers, not in an aftermarket pod. Exactly,thank you. I have AP f/glass ones and 6.5'' blaupunkts,don't think it would be too easy to get a 7'' in them,depends how much larger the housing is than the cone,some makes can vary in that size. Good luck on the AA ones....200watt and $39.50 (IMG:style_emoticons/default/dry.gif) |
| DBCooper |
May 3 2016, 02:29 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
| Creamsicle New Zealand |
May 3 2016, 02:34 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand |
I purchased a pair of factory replacement speakers from AA. Part # B914464550310P.
Had to grind small piece of each corner off then they where a perfect fit for the original speaker covers. They have a very small magnet which keeps the depth to a minimum. look great, look original. Not bad sound. Cost was $88.50 |
| ripper911 |
May 3 2016, 03:15 PM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I looked at the AA item and did a bit of googling and it turns out that AA is selling the Sound Storm Laboratories GS246 Gs Series 4X6" 2-Way Speaker 200W. It's available on eBay and Amazon. I still wonder if it will fit in the factory pods. Orbit398, if you do get them, please let the community know if they fit. Thanks. I have them in my car. They fit, but you have to install them at an angle. |
| Mikey914 |
May 4 2016, 12:17 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
DXI's aren't supre cheap but work well in this application with our fiberglass pods.
http://www.crutchfield.com/p_107DXI651S/Po...io-DXi651s.html |
| rfinegan |
May 4 2016, 09:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
What speakers do you have in the PIC?
So where do you think the 914rubber pods go? They replace the brittle, funky shaped Factory enclosures. ![]() |
| iankarr |
May 4 2016, 12:07 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I would be interested to know if the AA speakers actually fit in the original holders. Assuming they do fit, I'd be interested to know if there is anywhere else besides AA that they could be purchased. I bought the same ones AA shows on Amazon. Link below. Make sure you order the 4 x 6 ones. Fit perfectly. They install at a 20 degree or so angle and fit two screw holes...enough to secure them to the original grilles. http://www.amazon.com/GS246-200-watt-auto-...i_detailpages00 |
| iankarr |
May 5 2016, 03:59 AM
Lo-Fi Version | Time is now: 5th November 2026 - 05:12 AM |
