FS Gas Tank 1970-1974 Very Clean $150 Bare tank, $250 Complete, Early Style Tank that uses a steel expansion tank |
bdstone914 |
May 7 2016, 03:00 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I pulled this tank from a 914 in a Pick a Part yard. It is a very clean tank with little surface rust and most of the original paint and white stamp markings intact.
I wiped down the outside and sprayed the inside with carb cleaner to remove most of the varnish that formed when the tank sat in the California sun with the last dap of gas in it. I have a set of cleaned nipples and nuts and will include them with new paper gaskets and a new screen. I can also supply a filler neck, expansion tank, fuel sender and or assemble it all with new gaskets. $150 Bare tank, $250 Complete. Prefer local pick up but will ship from 92505 CA Attached thumbnail(s) |
bdstone914 |
May 7 2016, 03:01 PM
Inside Picture
rhodyguy |
May 7 2016, 04:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Clean reserve well.
flmont |
May 8 2016, 09:54 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Ill take that tank,..if it fits a 76' and if its that clean thru-out the whole tank,.??
Thanks Frank |
bdstone914 |
May 8 2016, 10:42 AM
Are you running the fuel injection ? One of the nipples willl have to be switched to the larger size for a 76. If you are running carbs you can just use a single outlet nipple on the tank.
It will fit into a 76. You will need the expansion tank, filler neck and gas cap that matches this tank. I have to check to see it I have a gas cap. Do you want the sending unit too? The early tanks have a bracket for the charcoal canister on the tank. 76 have it in the engine compartment. You could keep the canister in the engine bay and connect the lines as needed. Maybe someone else can comment regarding retro fitting an early tank to a late car. Bruce |
flmont |
May 8 2016, 10:59 AM
well,...my car is getting a 3.6 suby conversion,so I would be doing a 1 way FI system anyway,..I just need the tank,...I have a 74 to rob from if I need the other items..
gcrotvik |
May 8 2016, 11:04 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Hi Bruce,
I need the tank for my 70 6 conversion if it's still available. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:09 AM |
