| Biggles |
May 9 2016, 05:38 AM
Member ![]() ![]() Group: Members Posts: 207 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi
Does anyone have a photo of how the early style ('69-71) repa seat belt labels looked both left and right? It's the shoulder ones I need. Thanks |
| toolguy |
May 12 2016, 02:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
You mean like these. .
They are sewn on with a single stitch left to right, located on the 'backside' of the belt just under the top fold over at the attachment plate Attached image(s)
| Biggles |
May 13 2016, 01:26 PM
You mean like these. . They are sewn on with a single stitch left to right, located on the 'backside' of the belt just under the top fold over at the attachment plate thanks but aren't they the lap strap ones ? Ive since found an image off a 72 car but not sure if they were the same both sides ? Attached thumbnail(s) |
| toolguy |
May 14 2016, 11:08 AM
Those are the 4 labels for early non-retractable belts. . the shoulder straps share the same number side to side. . the Lap Belts have separate numbers because they are side specific due to the red release lever positions. Here is what I have for retractable belts. this is on the lower frame rail mount end for the across shoulder retractable belt Attached thumbnail(s) |
| Biggles |
May 14 2016, 03:04 PM
Those are the 4 labels for early non-retractable belts. . the shoulder straps share the same number side to side. . the Lap Belts have separate numbers because they are side specific due to the red release lever positions. Here is what I have for retractable belts. this is on the lower frame rail mount end for the across shoulder retractable belt Hi, thanks. I can't really see your first image too well but it looks like the two identical ones read 914 803 133 10 which I can't find in the PET catalogue ? And why would it be different to the one I saw in the picture 914 803 135 10 , with the G 462 ref below ? |
| toolguy |
May 14 2016, 04:47 PM
You have to look for individual listing for 914-6 or 70-71 914 USA version. . the picture in the parts book only shows the later belts, but early ones are listed in the listings
The belt you have posted has the center yellow strip. . USA belts did not have that stripe. |
| Biggles |
May 15 2016, 02:15 AM
ok thanks for your help.
sounds like i've got the right one as mine are european with the stripe. |
| vramani |
Feb 27 2018, 12:26 PM
Newbie ![]() Group: Members Posts: 1 Joined: 21-February 18 From: Houston Member No.: 21,913 Region Association: Southwest Region |
Toolguy can you call me need to know the source to order the tags please. Are you using the the Shaw guy in CA?
Lo-Fi Version | Time is now: 19th November 2026 - 11:39 AM |
