Another 914 gives its life so others can live |
Gunn1 |
May 9 2016, 06:20 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Gunn1 |
May 9 2016, 06:27 PM
whitetwinturbo |
May 9 2016, 09:07 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
...........what's up with that bullet hole in the roof (IMG:style_emoticons/default/dry.gif)
billh1963 |
May 10 2016, 01:28 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
CB Antennae...10-4, Good Buddy! (IMG:style_emoticons/default/biggrin.gif)
914time |
May 10 2016, 01:52 PM
Member Group: Members Posts: 68 Joined: 7-August 14 From: St. Paul, Minnesota Member No.: 17,750 Region Association: Upper MidWest |
What is the story with these two? Where did you find them? Are they both sacrificing to donate to a good one? Years?
mb911 |
May 10 2016, 01:55 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am amazed that we keep letting these cars go.. Looks savable my car was just marginally better then that when I bought it..
What's the story with them? |
iwanta914-6 |
May 10 2016, 01:59 PM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
I am amazed that we keep letting these cars go.. Looks savable my car was just marginally better then that when I bought it.. What's the story with them? I think sometimes its just easier/cheaper (if you have the room) to buy multiple "parts" cars than to try and source certain parts for a build. Of course if prices ever get to be anything like the 356's then he'll be kicking himself for cutting them up for parts. Here's another "parts car" for ya over in Wisconsin. http://minneapolis.craigslist.org/wsh/cto/5570964871.html |
Gunn1 |
May 10 2016, 03:32 PM
All I can say is its tough out here in the country! In all seriousness the targa had two holes in it when it was purchased, so not certain what caused them |
Gunn1 |
May 10 2016, 04:00 PM
I am amazed that we keep letting these cars go.. Looks savable my car was just marginally better then that when I bought it.. What's the story with them? I guess it cold be said anything is salvageable with enough time and money invested. The green car is a 72, the previous owner had stored it outside with the front drivers door window broken out of it, so after sitting out in the elements for who knows how long and housing many generations of Rodents in the front and rear trunks, and numerous cats in the drivers compartment it had seen its better days. That floor jack under it in the picture is there for a reason, If I were to remove it the car droops to the ground in the middle. the Longs are almost totally gone, with the exception of the top portions under the sill plates. The only thing keeping the floors intact is the black mastic sound deadening material. When I put the binders on it to haul it home the swing arm consoles where so far gone they just gave way and ended up allowing the rear wheels to splay out "Pigeon toe". It still has a running 1.7 liter in it with the transaxle still in it, clutch and so on. I have another 72' with a not perfect but much better body rust wise, the longs need work but not huge and of coarse the hell hole needs work as well. But all the rotten suspension mounting points on the green car, are solid on the other 72' which is currently painted and incorrect red, which will be brought back to its original "Sun flower yellow" I will be removing the mechanics this weekend, then start working on the red/yellow car body. |
Gunn1 |
May 10 2016, 04:16 PM
Gunn1 |
May 10 2016, 04:23 PM
I am amazed that we keep letting these cars go.. Looks savable my car was just marginally better then that when I bought it.. What's the story with them? I think sometimes its just easier/cheaper (if you have the room) to buy multiple "parts" cars than to try and source certain parts for a build. Of course if prices ever get to be anything like the 356's then he'll be kicking himself for cutting them up for parts. Here's another "parts car" for ya over in Wisconsin. http://minneapolis.craigslist.org/wsh/cto/5570964871.html Don't think I will be kicking myself anytime soon...Whatever parts remain will be put up for sale on the world for reasonable prices to help out other 914 enthusiasts, or I will hold on to them and build another car. Nothing will go to waste. No worries |
Chris H. |
May 11 2016, 08:15 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Don't feel bad about that one. It's gone. Time to harvest the organs. Fixing a 914 that has folded up in the middle is reconstruction. The Targa opening is way off. If there was sentimental value or it had some provenance then sure, do it, but really only a professional can fix that correctly. You're talking about (many) tens of thousands of dollars by the time it gets painted. Have to have a Celette bench to ensure it was all lined up perfectly. Plus...you probably haven't found all of the rust and/or bondo yet (IMG:style_emoticons/default/biggrin.gif) .
Gunn1 |
May 11 2016, 02:52 PM
Don't feel bad about that one. It's gone. Time to harvest the organs. Fixing a 914 that has folded up in the middle is reconstruction. The Targa opening is way off. If there was sentimental value or it had some provenance then sure, do it, but really only a professional can fix that correctly. You're talking about (many) tens of thousands of dollars by the time it gets painted. Have to have a Celette bench to ensure it was all lined up perfectly. Plus...you probably haven't found all of the rust and/or bondo yet (IMG:style_emoticons/default/biggrin.gif) . (IMG:style_emoticons/default/agree.gif) |
Gunn1 |
May 14 2016, 07:56 PM
some further photos of the donor car....
hoping to put some of the folks minds to rest out there that without a lot of time and or money this car couldn't be saved. the left and right consoles are totally rotted out under the hell hole is the Black hole! got the engine and transmission out it though Although the unibody is pretty much gone I have gotten a lot of good parts from the car. front tinted window, front window molding, many good interior parts, tail ligh t lenses, some good weather stripping, door handles, Blaupunkt radio, rear widow with defrost element, various fasteners, bolts, nuts, relays, wiring.....well you know And now the engine and tranny. I need to dive into them more and see what kind of shape they are both in. |
zambezi |
May 15 2016, 12:05 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
That rear bumper looks pretty straight
Gunn1 |
May 15 2016, 01:09 AM
Krieger |
May 15 2016, 10:38 AM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Wow that car is toast!
Gunn1 |
May 15 2016, 01:49 PM
Lo-Fi Version | Time is now: 10th June 2024 - 03:22 AM |
