Should have known Better, well actually I did |
76-914 |
May 13 2016, 06:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
In my rush to discover the clunk noise coming from the front end 5days before Rt66, I got sloppy. I sat the outer wheel bearings upon a piece of dirty cardboard vs. a clean baggie, when dropping the struts. The one damn time I break the rule it bites me in the butt. (IMG:style_emoticons/default/headbang.gif)
I originally thought the noise was the tire separating, which would have been Ron's fault for making me exceed my tires speed rating on our way to Rt66. (IMG:style_emoticons/default/shades.gif) When we returned I put it on the lift and when spun the L wheel had a rough spot. Pulled it apart and sure enough the outer bearing is toast. Bearings only had 7K on them. Damn it! And I did both sides the same so look out R side. Time to do both sides; again. Laziness shows no mercy. (IMG:style_emoticons/default/bootyshake.gif) |
r_towle |
May 13 2016, 08:12 PM
Custom Member Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It could still be blamed on Ron, was there a weight differential from one side of the car to the other?
76-914 |
May 14 2016, 07:28 AM
It could still be blamed on Ron, was there a weight differential from one side of the car to the other? Uhh Rich, that's a loaded question that I dare not answer. Never know when my co-pilot might log on. (IMG:style_emoticons/default/lol-2.gif) |
rhodyguy |
May 14 2016, 08:56 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The correct answer would be NO. 'Perfect balance on the corners'. All bases covered.
Lo-Fi Version | Time is now: 17th June 2024 - 02:08 AM |
