raw1298 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California ![]() |
There is a nylon or plastic bushing on mine, should I grease this or run it dry? What grease should I use if I need to?
Attached thumbnail(s) ![]() |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
I did ...right or wrong I could`t tell you..but I lightly grease all moving parts...take that arm apart and see how the rubber bushing is mine looked OK until I removed it I made new ones from nylon dowel,,good luck
MikeC |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
Powdered graphite is ok.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
The wrong grease will disolve the nylon bushings. Should not need lube but Pelican does carry the correct lube.
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Weltmeister sold special Lube for there swaybar. That's what I used over the years. Keeps it from squeaking.
Lo-Fi Version | Time is now: 10th June 2024 - 07:24 AM |
